WTB 69-72 4wd front spring & cast shackle hangers .
WTB 69-72 4wd front leaf spring hangers,must have radiator support brackets still mounted with tight rivets and the cast shackle hangers.
No rust pits, please post pics,price shipped to 37721. Thanks
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
![]() Join Date: May 2011
Re: WTB 69-72 4wd front spring & cast shackle hangers .
I have a set listed I'll see if I can find the link.
#4 | |
Passenger side looks fine
Drivers side does have a pitted spot on the inside edge which the radiator mount will cover. There is no other issues are the edges.
are the rivets tight? whats the total shipped?
Yes the rivers are tight and I'll get you a shipping quote tomorrow morning.
Shipping will be 29 let me know if still interested. I just realized I was looking at the wrong spot I will get a picture of that edge cleaned up tomorrow night. I pretty sure it is fine but will double check.
Please let me know on the other rust section.
Let me know if you need anymore pictures.
Pm sent.
#13 |
Found another set but they are rough the one rad. mount is gone I have one to replace it but then it would be bolted on. They also have heavy pitting. I will also separate the cast iron pieces and shackles if you want those.
Here are the blocks and u-bolts I found will separate if you want one or the other. 50 for everything or 20 for the blocks and 30 for the u-bolts Do you need the spring stop that bolt to the frame behind the driverside spring? 5 ea. |
#14 |
Sending PM with more questions
I will pass on front spring hangers , U bolts . Thanks
#15 |
The blocks are tapered and the axle and spring surfaces are fine.
#16 |
I do have another set they are bolted to the springs with the center bolt and that is used for the pin. They are tapered don't know if you can pick that up on the picture.
#17 |
Let's wrap this up, Pm with the list.
#18 |
I was wrong they weren't bolted on I just needed a bigger hammer LOL.
#19 |
Payment sent!
#20 |
Received should ship out tomorrow. Thanks
