Old 09-25-2018, 10:46 AM   #1
msg
Sway bar install after or before?
I am nearing the point of re assembly of my 66. Anything that was bolted together was removed. For the frame and suspension after breaking it all down years ago, parts were sandblasted and repainted. Some I need to just buy replacements for though. But I never had a sway bar on the front end and I am trying to get the right order of assembly down. Once I find a sway bar that will work with a stock height with power steering added I thought that installing it before I put the engine and transmission, cab and panels back on the frame would be easier. But I wasnt sure if it needs to be installed under a full load?
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 09-25-2018, 11:09 AM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Sway bar install after or before?
Doesn’t really matter. Get one from a 73-89 3/4 ton, they are much bigger, or you can go aftermarket, they are usually powder coated and all pretty.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-25-2018, 08:02 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
It doesn't matter much about the drivetrain being installed. It is a bit easier without the radiator support bolted in place.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 09-26-2018, 08:31 AM   #4
msg
I'll check the local part yards around, but I will be so new at it all I can ask is what you typed there. Ill see what they say. Ive read from other posts that 1- 1/4" circumference on the bar is pretty beefy and recommended. Also the types that mount to the control arms are best for the stock heights.
I didnt take many detailed pics of the front end before I did the teardown.
Heres about all I can find
Then a few as I did removal
Then had some parts sand blasted and I painted them
Good to know, thanks!
Old 09-26-2018, 09:24 AM   #5
Clyde65
Clyde65's Avatar
If your lowered like mine, look at aftermarket like CPP for the lower sway bar mounts at the frame..
https://www.classicparts.com/mobile/.../74%2D806%2D3/
Clyde65
Rebuild of Clyde
support our troops!
Old 09-26-2018, 11:40 PM   #6
DPowers
DPowers's Avatar
Great info in these two threads.
http://67-72chevytrucks.com/vboard/s...d.php?t=517255
DPowers is offline   Reply With Quote
