Hydroboost from 2001 2500 to a 67 C10
Hey all, I've got a completely free hydroboost setup from a 2001 2500HD. It's got the booster, MC, all lines, cooler, etc. I've researched other threads and the mount to the firewall looks identical to the earlier units I've seen so I have little doubt that I can make that end work. My questions are around the MC itself - any bore, stroke issues? And, the MC reservoir is huge and ugly! Would an earlier MS with a smaller reservoir fit this later booster. I've looked on RockAuto comparing part numbers and, by that, everything's different.
Can anyone help answer this question? Thanks All! |
All about them K’s
![]() Join Date: Jun 2014
Re: Hydroboost from 2001 2500 to a 67 C10
I bolted a stock 72 master to my 08 hydraboost setup with no problem. I used the original proportioning valve and everything. The last page of the link in my signature has more details.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
I have a booster from a 2003 with a stock 1972 master. I use an aftermarket prop valve.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914 1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161 |
Great. I was thinking that was probably the case but just wanted to make sure.
Thanks Guys!!! Truly, much appreciate both of your responses. |
