09-26-2018, 05:22 PM | #1 |
Brake dummy light on dash is on
What makes this light come on?
Edited to remove all additional info. All I want to know is what makes this light come on. What switches open or close to put power to that bulb.
2007 GMC 2500 CCSB LBZ 1991 GMC 1500 RCSB 350 1981 GMC Street Coupe RCSB 454 Last edited by SKR; 09-30-2018 at 01:03 PM. |
09-26-2018, 11:32 PM | #2 |
Re: Brake dummy light on dash is on
Check the emergency brake pedal, be sure its all the way up.
09-27-2018, 07:41 AM | #3 |
It also comes on with low fluid/pressure.
09-27-2018, 08:10 AM | #4 |
It could be the fluid is low or the float is stuck, in the master cylinder.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR Last edited by TKCR; 09-27-2018 at 08:22 AM. |
09-27-2018, 08:55 AM | #5 |
Removed.
09-27-2018, 09:09 AM | #6 | |
https://www.youtube.com/watch?v=CiYnznl2E1w
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
09-30-2018, 11:29 AM | #7 |
Removed. Not interested in anything other than the question in the first post.
2007 GMC 2500 CCSB LBZ 1991 GMC 1500 RCSB 350 1981 GMC Street Coupe RCSB 454 Last edited by SKR; 09-30-2018 at 01:04 PM. |
09-30-2018, 05:38 PM | #8 | |
Low brake fluid, or at least the float thinks it's low. Emergency brake is on. These are the minor things it could be. Here's something easy to try. On my 01 Honda CRV, my brake light kept coming on and the reservoir was full. So I took the screen out and cleaned it real good and let it dry before putting it back in. The screen had some sediment in the bottom, so I assume it made the float think that it was low on oil. It made the light go out and I never had any issues with the light coming on. Now I've never seen the inside of our reservoirs, but I'm going to assume they have a screen too. It's worth a shot
09-30-2018, 05:50 PM | #9 | |
If the float thinks the level is low, how does it tell the light to turn on? That's what I want to know.
2007 GMC 2500 CCSB LBZ 1991 GMC 1500 RCSB 350 1981 GMC Street Coupe RCSB 454 |
09-30-2018, 06:01 PM | #10 | |
But something else that makes the brake light come on, is a bad brake switch. The switch is down where the brake pedal is. Or if there is a fuse for the brake light, it might be blown, making the light be stuck open/on.
09-27-2018, 08:58 AM | #11 |
Remove the bulb.
09-27-2018, 09:28 AM | #12 |
My guess then is something is shorting out either in you gauges or more than likely something got pinched to where it is putting voltage to that wire (should be a tan w blk strip). Depending on where you disconnected it under the hood, it may be pciking up a voltage on that tan w/Blk wire.
09-27-2018, 10:16 AM | #13 | |
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
09-30-2018, 02:50 PM | #14 |
Start easy, unplug the parking brake switch (you will see a wire attached to the mechanism, when you set the parking brake, it grounds, turning on the light).
Next, unplug the wire at the brake distribution block on the crossmember behind the rad. Same deal, if the switch grounds, the light lights. Light go out when you unplug one of those items? Which one? And looking from one of your quotes, you got a little over enthusiastic deleting stuff since it hints at something being unpluged. Alex. |
09-30-2018, 05:49 PM | #15 |
I deleted everything because people were getting sidetracked with the other info I added. I was going to get lots of answers why the light could be on, but not how the light could be on. There's a difference, and I can figure out the why if I know the how. So to simplify the answers I took all that out.
So I can check the parking brake switch. The distribution block is unplugged, and has been for a year or so now, so that's not the problem. Is there anything else?
09-30-2018, 05:52 PM | #16 |
The plastic circuit boards on these dashes are not very good IMO. Something may be causing power & ground to get to that section of the circuit board. Myself, I would just pull the bulb, unless you want to pull the dash and look gor a short/ground issue (big pain)
10-01-2018, 04:20 AM | #17 | |
The brake light illuminates when a path to ground is established on any of the legs of the TAN/WHT 33 circuit. The dwg below illustrates the printed circuit wiring. Red tracer is power and blue is ground: After leaving the instrument cluster connector the TAN/WHT 33 lead is immediately branched off in two directions. One leg goes straight down to the e-brake switch and the other heads to the main firewall bulkhead connector block: At the bulkhead connector (on the cab side) a third ground leg is spliced into the one that goes through the firewall - and then out to the brake warning switch. That third leg goes up through the steering column and into the ignition switch. Most people don't notice but when the key is in the START position, the TAN/WHT 33 is grounded causing the e-brake light to come on (the sensing leg for the coolant temp gauge - DK GRN 35- is also grounded, making the gauge spike full high). Both return to normal when the key is released. By disconnecting the leads at the e-brake and warning switches, you have eliminated those components. But there is a lot of wiring between them and the brake light. A ground fault in any of those leads will light the dash light. The leg to the ignition switch - and the switch itself - has yet to be tested as well. If it seems to be in the ignition switch or its associated wiring - I would seriously consider simply cutting the wire at the bulkhead connection - rather than tearing into the column. |
10-01-2018, 07:39 PM | #18 |
Beautiful. Thank you.
