Heads manifolds
Hi folks:
Do you know if the heads manifolds can be paint coated whit high temperature paint? |
![]() Join Date: Jan 2001
Re: Heads manifolds
Intake manifold, exhaust manifolds, and heads can all be painted. Exhaust manifolds will require very-high-temperature paint - plan on 600 degrees or so for a normally-aspirated GM engine.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Re: Heads manifolds
Thank you so much TRUCKSTER.
one more question:is it easy to buy the paint? |
Re: Heads manifolds
It is for most of us, not sure about California.........
Local auto parts stores, Summit Racing, Jegs, etc all stock different types of engine paint. Ive had good luck with VHT brand. |
Re: Heads manifolds
Look here for high temp paints and coatings.
https://www.eastwood.com/ |
Who Changed This?
![]() Join Date: Jan 2013
Re: Heads manifolds
I bought high heat clear for my Buick exhaust manifolds at O'Reilly's.
Re: Heads manifolds
Thank you so much
This is a lot of info gave me more ideas Have a good day |
Re: Heads manifolds
There a YouTube video out there where the VHT high temp stuff was tested on headers. These guys first tested at normal heat and found the VHT high temp stood up just fine.
Then they retarded the timing and went for a super high heat run. The VHT paint held up once again. Don't have a link sorry. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
