Old 09-27-2018, 04:37 PM   #1
BigCountryx
BigCountryx's Avatar
Headlights flash with turn signals
72 Blazer - with the headlight switch turned off, they flash along with all of my dash lights when my turn signals are turned on. I feel like it's a ground issue, but what grounds should I start with? Dash ground, where is that located? Headlight grounds Turn signal grounds maybe? I hate electrical issues.
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped
1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant
BigCountryx is offline   Reply With Quote
Old 09-27-2018, 04:51 PM   #2
Chris_oz
Chris_oz's Avatar
Re: Headlights flash with turn signals
It's the turn signal ground, try to see if only one direction does it.
Do the tail lights flash too?
Chris_oz is offline   Reply With Quote
Old 09-27-2018, 11:15 PM   #3
BigCountryx
Both directions do it and the tail lights dont flash like the headlights.
Old 09-28-2018, 10:09 AM   #4
tdangle
tdangle's Avatar
When ever I track down a problem like this, it does seem to be ground problems. Check the grounds at the headlight bulbs and the turn signal bulbs. also double check the bulbs. Once had a bulb filament break and short to the other filament causing all sorts of strange issues. this was at the rear bulb
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 09-28-2018, 12:10 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
As far as ground strap locations read through this thread....
http://67-72chevytrucks.com/vboard/s...d.php?t=422234
LockDoc
Leon
