Old 09-27-2018, 08:49 PM   #1
Brentwe
1966 k10 heater core
My new to me 66 short had a bad rad cap, replaced it and very shortly there after started smelling a bit of coolant. Any who, heater core is shot and thanks to the help on this forum for directions on heat box removal.
For those into this, there is a couple of sizes of cores, 7 inch and 9 1/2 inches long. Check the specs before you order. 2nd one on order now.
Brent W
66 short step
4 x 4
Brentwe is offline   Reply With Quote
Old 09-29-2018, 10:01 PM   #2
Brentwe
Re: 1966 k10 heater core
New one arrived today, install required grinding out the slots on the 3/4 inch outlet for clearance. The spacing between the 2 pipes was not quite factory The heat is on.
Brent W
66 short step
4 x 4
Old 10-01-2018, 02:50 PM   #3
87warrior
My K20 is in need of a new heater core as well. Is it possible to determine which size core I need without removing the heater box 'lid'?
Where did you go for the new heater core?
87warrior is offline   Reply With Quote
Old 10-02-2018, 12:22 AM   #4
Captainfab
60-66 Nut
Typically the Economy heater has the smaller core and the Deluxe heater has the larger core.
Old 10-02-2018, 01:15 AM   #5
Brentwe
The above is correct, but you can pull the top off the unit easy enough and see the coil, can't remove it until the box is removed, it comes out from below. But you will see enough to measure the length.
The deluxe (9 inch) is Spectra Premium 94691, local shop ordered it, I think Spectra is a fairly common brand.
Brent W
66 short step
4 x 4
Old 10-02-2018, 10:04 AM   #6
LT1 Burb
LT1 Burb's Avatar
I took my original heater core in and had the tanks unsweated on both the repop and old ones and then swapped them. I couldn't take the fit and it would have irritated me.
LT1 Burb is offline   Reply With Quote
Old 10-03-2018, 12:29 AM   #7
Brentwe
Looks good.
Brent W
66 short step
4 x 4
