Old 09-28-2018, 01:29 PM   #1
bes12394@gmail.com
Steering column length?
Wanting to put a tilt steering column in my 66. What length column are you guys using? Heard that a 32" should be about right. Or is it more personal preference.
bes12394@gmail.com is offline   Reply With Quote
Old 09-28-2018, 03:08 PM   #2
LVPhotos
LVPhotos's Avatar
Re: Steering column length?
Ididit standard is 35" and new rack & pinion version at 30"
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 09-28-2018, 05:27 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
The Ididit 1960-66 GM Truck Retro Series tilt column I run in my truck is 32" long from shaft end to end.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 09-28-2018, 07:49 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
End of the housings end to end? or end of the shafts end to end?
Old 09-28-2018, 08:20 PM   #5
vin63
vin63's Avatar
shaft - splined end to splined end.
Old 09-29-2018, 07:56 AM   #6
The Rocknrod
Moderator
Thank you.
I havnt ordered mine yet and the reason I asked is (as you know) ordering one they use these measurements (from Ididit):
