Old 09-28-2018, 05:23 PM   #1
C-cab23
C-cab23's Avatar
One ton frame
I have a 68 gmc stepside lwb one ton. Can I replace all the suspension parts with half ton parts to get a better ride ? Thanks
C-cab23 is offline   Reply With Quote
Old 09-28-2018, 07:41 PM   #2
notsolo
notsolo's Avatar
Re: One ton frame
Yes with a front cross member swap, frame is probably taller. Rear springs also may be wider you might have to replace spring shackles. If you had a donor truck that woild help.
notsolo is offline   Reply With Quote
