Need some quick help...
I am about to install my timing chain, and I was wonder what is best for a 72 3/4 ton with a 350. Should I advance it for more low end, or retard it for top end? Or do these trucks go just fine with it set normally?
Thanks, Scott
1972 C10 1972 C20 ![]() |
The instructions with the performance cam you have should specify if it will perform better with a change from stock. If not, I would line up the marks and bolt er' in. You can play with the timing later for different results also.
69 GMC K10 ..some restoration required....still.. ![]() |
I have a Crane 266 cam in there, I will read and see what it says tomorrow when I get back to the shop...
![]() Join Date: Aug 2001
![]() I ALWAYS JUST SET EM NORMALLY (0 DEGREES) AT INSTALLATION, & ADJUST ACCORDING TO YOUR ALTITUDE WHEN IT'S BACK TOGETHER. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
lope....lope....lope...lope....lope....lope... oh sorry i was listenign to the custom ground cam in my mind
70 longbed 496/th400/Ford 9" |
