Old 09-30-2018, 07:36 AM   #1
frankyboy455
TF side cowl gutter modification
I'm currently replacing the outer cowl panel on a 57 TF and I'm quite certain I saw in a thread someone making modifications to the gutter design.
Not sure if it was just an angle change or a relocation, but I know I saw it.
I've been searching this thread/pics since last night and for the life of me, just can't find it.
If someone could direct me to this thread, it would be very appreciated.
Frank.
frankyboy455 is offline   Reply With Quote
Old 09-30-2018, 12:34 PM   #2
dsraven
Re: TF side cowl gutter modification
are you talking about the trough spot welded above the floor vent?
Old 09-30-2018, 12:41 PM   #3
dsraven
some guys delete the vent panel in front of the windshield because they won't be using the floor vents and will be using recycled cabin air if the heater/ac is used. that way leaves, pine needles and water can't get into that space and cause rust again. some are also using a different drain set up at the bottom of the side cowl panels because the stock metal flap at the bottom tended to be too small to let anything through if needles or leaves did get in there. then the cowl filled with water and drained out onto the cab floor, which is what caused a lot of floors and hinge pillars to rust out badly.
do you plan to use the stock vents and heater etc? I repaired mine but may cover the vents with some screw on covers in case I need to get back in there at some point. my configuration is different than stock as I am using a donor frame and partial floor pan along with the heater a/c unit from the donor.
Old 09-30-2018, 07:08 PM   #4
frankyboy455
Yes, the gutter just above the oval opening.
Old 10-08-2018, 04:34 AM   #5
bobinbc
bobinbc's Avatar
A member named Roger built a very nice green 57 and he modified the gutter by slanting it I believe
1962 Chevy blue SBFS
1957 Chevy yellow SBSS
1956 GMC red SBSS Nov 2017 ToTM
https://www.facebook.com/groups/Cana...geChevyTrucks/
bobinbc is offline   Reply With Quote
