Stock to Dual Exhaust Starter Routing
I searched quite a ways back and I didn't find what I'm needing help with. Im thinking of taking out my stock Y-pipe single exhaust and running true duals. The passenger side down pipe is shaped around the starter and has a pretty deep depression to clear the starter. Does anyone have pictures of how the routed their dual exhaust down pipe? Will I have to replicate the indention to clear the starter? This is for a 70 c10 with 350 and TH 350 trans and rams horns. I'm not going the high toque mini-starter route. I have no idea how to make this work or even how to direct my local muffler shop. Any suggestions or examples? I'm stuck.
Thanks!! |
Re: Stock to Dual Exhaust Starter Routing
https://www.summitracing.com/parts/h...del/c20-pickup
Pretty much down and back, then an angle at the bottom. I don't remember an indentation in my old exhaust system with the factory manifolds, but that had a 2" pipe.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
I have the exact setup as you. Installing a mini starter will eliminate any interference with down pipe. After removing the original style starter I would never go back to that big heavy Delco type. Many advantages with high torque mini. Weight, cost and simplicity of instillation.....
71 C-20 07 Magnum RT AWD |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
I have the same 350/350 setup on a 72 LWB C10 and took mine to a muffler shop and told them I wanted true duals from the rams horns back. I have a normal starter and they did what I asked and I had an H pipe added as well. Sorry I do not have a hoist or I'd post pics for you.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#5 | |
Thanks! |
Here is how I had the exhaust exit the truck.I wanted the pipes a little further back to look like the pipes on the black truck but because of the factory auxiliary spring set up that's as far as they could go. The link is what I use for mufflers and it gave me the sound I wanted. We can't post videos on here but if you want to hear mine running PM me your personal email address and i'll send you a video of the truck running. The mufflers are sideways under the truck. In case the link just takes you to the site i used part number 17747 on my truck.
http://www.dynomax.com/super-turbo-c...ffset-640.html
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 Last edited by Already Gone; 10-02-2018 at 08:16 PM. |
As simple as it gets
Do it, Do it right, Do it right the first time |
Old member
Just take it to a good muffler shop and they will take care of it for you. The only thing is next time you have to take that big ass starter out you may have to undo the exhaust to get it off.
This is why the mini starter is nice. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#9 | |
One last question, should i retain the factory heat riser? I'm in the sunny south so cold starts are not an issue. Come think of it I'm not sure the one I have even works. Thanks again. |
#10 | |
Old member
![]() Quote:
I have done the LS swap in my 71 with headers. I hope I never have to mess with a starter! ![]() ![]()
I have a regular starter and an NV3500 5 speed. I can remove the starter without removing the exhaust. I only remove the hydraulic slave cylinder below the starter.
Now that i think of it I had the exhaust installed in 2015 and last year had the starter replaced and nothing was said about having the exhaust interfere with the starter R & R..
#13 |
I've been following this waiting to see if anybody had anything to say about the Hooker dual exhaust kit (16621HKR). The down pipes look the same on both sides. The reviews on Summit Racing are mixed. One person said they hang too low, but others say they fit perfect. I'd like to try it because it has mandrel bends and a decent price. I'd really like to see some pictures of it installed.
#14 |
The shop should be able to manage any issues you have with interference and with future ease of replacement of the starter or other parts under there.
Let them decide and then have them show you before they weld it up. Hth, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#15 |
Talked to the shop and taking it on Monday. This is definitely the right place to go. his first question was how to I intended to use the truck and cautioned against going too big with duals for a bone-stock 350 used as a daily driver. not sure a lot of shops would recommend sticking with a single exhaust when they have the opportunity to sell a dual setup. He also builds the system so you can tryout different mufflers to get the sound you want before before you leave. I see how it goes.
#16 |
Old member
