Old 10-01-2018, 05:34 PM   #1
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Astro Hydroboost - What master cylinder?
I have a 95 Astro van hydroboost and the Astro master cylinder. I would like to run a more modern looking master than the 71 cast iron one. I'm not sure what modern cylinders will work with both my boost and the disc/drum set up. I also assume I will have to use my original proportioning valve?? I don't want to spend the Willwood prices.
I did a search on the forum, but after an hour I found no definitive answer.
Any help is appreciated.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 10-02-2018, 12:12 AM   #2
v30crewcab
v30crewcab's Avatar
Re: Astro Hydroboost - What master cylinder?
I use the astro master as well as the prop valve. works good.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 10-02-2018, 05:53 AM   #3
Bigdav160
Bigdav160's Avatar
I used my original MC and valve. I only changed the vacuum booster with the hydraulic one (HB)
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-02-2018, 07:33 AM   #4
Keith Seymore
Keith Seymore's Avatar
There are a million ways for a master cylinder to not be a good choice: bore diameter, quick take up vs non quick take up (affects the portion that goes into the booster), ISO flares vs US flare type, inboard ports vs outboard ports, front port goes to the rear system vs front port goes to the front system, to name a few.
Having said that I think the Astro hydroboost is a good choice.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-02-2018, 09:09 AM   #5
1971Stepside
Almost Satisfied
Are you running disc/drum and have had no issue using the prop valve and master from the Astro?
Old 10-04-2018, 05:41 PM   #6
v30crewcab
v30crewcab's Avatar
I've run it both ways and it works. they are disc/drum in the astro so if thats what you are running it will be good.
71 longbed 5.3 4l80
Old 10-04-2018, 06:48 PM   #7
Slowguy
Where’s the best place to get a complete Astro setup other than a pick and pull? If I search ebay all I find is just the hydroboost without the master cylinder.
Slowguy is offline   Reply With Quote
Old 10-04-2018, 07:45 PM   #8
jeffahart
jeffahart's Avatar
You can get on the phone and call dismantlers. I thinks a lot of the stuff on ebay is dismantlers anyway.
j
White K20
jeffahart is offline   Reply With Quote
Old 10-05-2018, 08:54 AM   #9
MARKDTN
Auto parts store, craigslist, junkyard.....
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 10-06-2018, 10:26 PM   #10
rustytruck50
rustytruck50's Avatar
I'm interested in this swap. Does anybody have any pictures? Am I able to use my stock MC?
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 10-07-2018, 12:13 AM   #11
57taskforce
All about them K’s
57taskforce's Avatar
Look at the last page in the link on my signature...
Tyler
57taskforce is offline   Reply With Quote
Old 10-07-2018, 03:15 PM   #12
rustytruck50
Will do....thanks!
-Doug
'05 RCSB Sierra 2WD
Old 10-08-2018, 01:05 PM   #13
bs46488
I've done 2 hydroboost setups.
1970 Nova - used the astro booster and MC for the Astro
1972 c10 - used a booster from an early 2000's silverado and the factory c10 booster
For both setups I used an aftermarket prop valve.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
