Old 10-02-2018, 08:30 PM   #1
Tenncman
Tenncman's Avatar
67 chevy wipers
First off hello everyone .Can someone help me figure out this gremlins. I turn my Wil e rd on low or high they won't work. But if I push on the sprayer button on the switch the wipers work but only for a few seconds. I can also control the speed of the wiper by pushing in the switch. But can't get them to work on the low or high setting.It h a s me scratching more than my head now.
Tenncman is offline   Reply With Quote
Old 10-02-2018, 08:34 PM   #2
Tenncman
Tenncman's Avatar
Re: 67 chevy wipers
Should say turn on my wipers on low or high they won't work. Sorry for the fat fingers
Old 10-02-2018, 09:41 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Re: 67 chevy wipers
You are only getting a ground through the Dark Blue wire to the wiper. Is the wiper switch mounted in the dash? If so, with the ignition switch on turn the switch to the low position, reach up under the dash and wiggle the connector on the back of the wiper switch to see if you have a bad connection there. Try the high position also. If that doesn't do anything take a jumper wire with alligator clips on both ends and connect one end to bare metal on the wiper (not the screws) and the other end to bare metal on the cab and see what happens. Post back
Edit: Also make sure that the connectors on the wiper are connected like the picture below.
LockDoc
Leon
Old 10-02-2018, 09:47 PM   #4
Tenncman
Tenncman's Avatar
Re: 67 chevy wipers
Lockdoc. The wiring looks the same as the picture. But what by connect one lead of the clip to the bare metal of wiper ? ( Do you mean the wiper arm ?)
Old 10-02-2018, 09:51 PM   #5
LockDoc
LockDoc's Avatar
Re: 67 chevy wipers
Nope, the wiper motor under the dash....
LockDoc
Leon
Old 10-02-2018, 09:54 PM   #6
Tenncman
Tenncman's Avatar
Re: 67 chevy wipers
Ok. Thank you will give it a try . If it works,than onto the gas gauge .lol
Old 10-02-2018, 10:04 PM   #7
LockDoc
LockDoc's Avatar
Re: 67 chevy wipers
All the wire does is to make sure you are getting a ground. If one of those procedures makes them work you are still not done with them. You will have to fix them so they keep working......
LockDoc
Leon
Old 10-02-2018, 10:08 PM   #8
Tenncman
Tenncman's Avatar
Re: 67 chevy wipers
So if I apply a good ground if the clips work. Would that take care of the issue found with the clips
Old 10-02-2018, 10:32 PM   #9
LockDoc
LockDoc's Avatar
Re: 67 chevy wipers
Yes, if it was a permanent wire. There is a small brass strap on one of the mounting screws that is the actual ground but it is hard to see unless you pull the motor out.
I added a picture of the ground strap on the wiper motor mounting pad.
LockDoc
Leon
Last edited by LockDoc; 10-02-2018 at 10:43 PM. Reason: Added picture of ground strap
Old 10-02-2018, 11:50 PM   #10
Tenncman
Tenncman's Avatar
Re: 67 chevy wipers
Ok. I just tried the jumper wire no change in condition. Reached hand up to back of switch wipers worked as long as I supplied lite pressure to the connector. Thinking I need to pull the switch and check both ends of the connector.
Old 10-03-2018, 11:40 AM   #11
LockDoc
LockDoc's Avatar
Re: 67 chevy wipers
Yes, try cleaning the terminals and make sure the nut holding the switch in the dash is tight.
LockDoc
Leon
Old 10-03-2018, 02:20 PM   #12
Tenncman
Tenncman's Avatar
Re: 67 chevy wipers
Found the issue with the wipers. Someone didn't put the retaining bezel nut on. Which cause a weak ground. Now onto the gas gauge.
Big thanks to Lock Doc
Old 10-03-2018, 03:56 PM   #13
LockDoc
LockDoc's Avatar
Re: 67 chevy wipers
Good deal. Glad you got it fixed. Post up a new thread on the fuel gauge if you can't figure it out.....
LockDoc
Leon
Old 10-03-2018, 04:22 PM   #14
Tenncman
Tenncman's Avatar
Re: 67 chevy wipers
Any ideas on where I can locate a bezel nit. The one the tightens the switch to the dash. Local hardware that usually has everything doesnt care it
Old 10-03-2018, 07:41 PM   #15
LockDoc
LockDoc's Avatar
Re: 67 chevy wipers
PM me your mailing address and I will send you one.... You will need the "Star" washer too. To PM me click on my board name over on the left side then click on "send a private message to LockDoc"
LockDoc
Leon
Old 10-03-2018, 08:02 PM   #16
Tenncman
Tenncman's Avatar
Re: 67 chevy wipers
PM sent. Thank you
Old 10-03-2018, 09:34 PM   #17
LockDoc
LockDoc's Avatar
Re: 67 chevy wipers
PM sent. Thank you
No problem I will mail them out tomorrow.
LockDoc
Leon
Old 10-03-2018, 10:01 PM   #18
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Re: 67 chevy wipers
This is why I love this board
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 10-03-2018, 10:04 PM   #19
Tenncman
Tenncman's Avatar
Re: 67 chevy wipers
I agree with you 71 Stepside. Best site I have found by far.
Old 10-03-2018, 10:17 PM   #20
Getter-Done
Getter-Done's Avatar
Re: 67 chevy wipers
Welcome
Yes this Site is (The Best)
The early bird gets the worm,
84 Chevy K-20
