Old 10-02-2018, 09:32 PM   #1
72 k15
72 k15's Avatar
72 4x4 BB swap?
I found a nice rebuild 402 for a good price Wondering how hard it is to swap a big block in i did some reading and read it doesn't fit properly?
72 k15 is offline   Reply With Quote
Old 10-03-2018, 11:28 AM   #2
68is4me
68is4me's Avatar
Re: 72 4x4 BB swap?
I am sure that it can be done. I know the 4x4's never came with a BB, so I think the only major hurdle would be the engine stands, and maybe an oil pan. I have seen people on this forum add the BB to the 4x4 so I know it can be done.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Old 10-03-2018, 12:55 PM   #3
72 k15
72 k15's Avatar
Re: 72 4x4 BB swap?
I actually don’t mind the 350 but it’s burning oil like a 2 stroke and most likely has 300k+ miles and I’d have so sell my extra engine I’m trading for instead of just trading for the rebuilt 402. So I would like to put the 402 in but no idea on figment anyone that has done this help would be appreciated.
Old 10-03-2018, 05:16 PM   #4
cypressbog
Go Pack Go!
Re: 72 4x4 BB swap?
I bought a 71 4x4 half-ton truck 17 years ago that had a BB prior to my purchase. The firewall was pounded on to make room for the distributor and the engine cradle was seriously cut to make way for the oil pan. It was upgraded to 8 lug axles from a mid-70's Chevy 3/4 ton truck.
If you're installing in a 1/2 ton with factory running gear, I'd worry about if the axles, drive shafts, and U-joints are strong enough.
cypressbog is offline   Reply With Quote
Old 10-03-2018, 06:47 PM   #5
72 k15
72 k15's Avatar
Re: 72 4x4 BB swap?
Not to worried on drive train strength only be 350ish go 400 tq
Old 10-03-2018, 06:55 PM   #6
Jeff's bowtie's
Re: 72 4x4 BB swap?
I've done this swap before. I moved the engine mounts 2" to the front of the frame a the trans crossmember as well to make room for the heads and hei distributor and then used a 2wd shroud but the you have to resize your driveshafts but then the engine looks like it belongs in the truck without beating the crap out of the firewall
Jeff's bowtie's is offline   Reply With Quote
Old 10-04-2018, 11:39 AM   #7
8cuda
Re: 72 4x4 BB swap?
Did you have to cut the floor for your shifter(s)?
Is this method for installing the a BB
1. Move motor mounts 2 inch forward
2. Move the transmission and transfer case mount 2 inch forward
2a. for manual trans, does the effect the z bar?
3. Increase the rear drive shaft
4. Decrease the front drive shaft
8cuda is offline   Reply With Quote
Old 10-04-2018, 11:51 AM   #8
Jeff's bowtie's
Re: 72 4x4 BB swap?
I used a high hump from a 2wd 4 speed and cut the hole for the transfer shifter and this makes up for the 2" moved forward and yes this is for a big block conversion and yes it does effect the drive shaft lengths and just move the Z-bar frame bracket forward as well
Old 10-04-2018, 12:38 PM   #9
landarts
landarts
Re: 72 4x4 BB swap?
I have a 402 big block in my 72 GMC 4x4. The firewall has not been modified, back of valve covers are close to firewall and distributor really close also. Does not look like anything was moved forward. If you need a measurement let me know.
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
