Old 10-03-2018, 04:17 PM   #1
beaterku
beaterku's Avatar
Stock 6.0 24lb vs. Flex 50lb injector info
Good afternoon, I ordered a flex fuel injector from a 2012 6.0 2500 truck to verify that it is the same mounting height as the stock 24lb injector.
For those of you who are upgrade injectors, here is a picture of the stock 25317628 22-24lb injector on the left, and a flex fuel 12613412 50lb injector on the right. The mounting height is the same. The flex fuel doesn't have the boot on the tip, which as far as I can tell, won't affect anything. The flex also uses the EV6 connector.
These are going to be more than enough injector for my needs, but was a pretty cheap upgrade.
beaterku is offline   Reply With Quote
