Old 10-03-2018, 08:39 PM   #1
Jonny Hotnuts
fuel filler eliminator, any tips?
Is there a kit or a patch panel?
What tank is typically used and where does it go? (*note that I will no longer have the spare OR need a huge capacity tank)
Where does the fuel filler get relocated?
Any drawbacks to doing the relocate?
Thanks for any advice!
~JH
Jonny Hotnuts is offline   Reply With Quote
Old 10-03-2018, 10:05 PM   #2
HO455
Post Whore
HO455's Avatar
Re: fuel filler eliminator, any tips?
Just to be sure. Are you wanting to remove the stock tank from inside the cab and replace it with an under bed tank or vice a versa? What style truck and year?
RIP Bob Parks.
Old 10-03-2018, 10:08 PM   #3
Zeroman
Zeroman's Avatar
Just use the search engine in the upper right portion of your screen to search this forum for rear mounted gas tank installations.
Zeroman is offline   Reply With Quote
Old 10-04-2018, 12:31 AM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
It's all custom fab work if you're moving your tank outta the cab, so you put the filler door/neck where ever you want it.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 10-04-2018, 01:02 AM   #5
Quikshft
Quikshft's Avatar
I put the filler in the wheel well. Probably not an option for a 2wd or lowered truck, but for a 4x4 it seems to work ok.
Quikshft is offline   Reply With Quote
Old 10-04-2018, 03:58 PM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
One of my younger brothers put a 22 gallon fuel cell between the rear tires, tucked up under the bed. It was all the bigger he could go, since the 18" wide tires needed to keep traction behind the blown 383 stroker took up a lot of room. And a good place for weight when racing. He had excellent fabrication skills, and worked out a fill pipe that was accessed by opening up the left tail light, like on a '56 Chevy. The cab hole was welded up and ground smooth before painting.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 10-05-2018, 08:08 AM   #7
FL71C10
Infantimachine. Com has nice patch panels for the hole
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 10-05-2018, 10:21 AM   #8
kenr74
I used a panel from LMC.
38-7621 about $10.
http://media.lmctruck.com/pdf/CB/0132.pdf
kenr74 is offline   Reply With Quote
Old 10-05-2018, 11:18 AM   #9
beaterku
beaterku's Avatar
I found this thread a while back. This is what I am planning on doing with my truck since it is already painted.
http://67-72chevytrucks.com/vboard/s...6&postcount=17
beaterku is offline   Reply With Quote
Old 10-05-2018, 11:54 AM   #10
CarolinaHD
Moderator
CarolinaHD's Avatar
Patch panel
http://classicheartbeat.com/catalog/...ler%20Plug.htm
http://classicheartbeat.com/fuel_parts.htm
Alex
1967 C50 292ci Lumber truck
1967 C50 292ci Dump truck
1967 C60 366ci Fire truck
CarolinaHD is offline   Reply With Quote
Old 10-05-2018, 03:07 PM   #11
cebra
I did the Wrangler tank with S10 fuel sender. Put the filler through the bed into a cut down ammo can on the bedside. I think it looks pretty decent and it was cheap ($100 new tank, $30 new sender, $30 fuel lines/hoses, $8 junkyard Wrangler filler/tank straps, $8 ammo can, $10 angle bracket/hardware). The reason I went with this setup was the tank is baffled and the sender will hold a EP381 fuel pump when I swap to LS. Downfall is it is 15 gallons and slightly slow to fill due to the small Wrangler fill hose.
cebra is offline   Reply With Quote
Old 10-05-2018, 07:08 PM   #12
PepperTreeGarage
PepperTreeGarage's Avatar
I put my filler in the rear corner of the bed.
PepperTreeGarage is offline   Reply With Quote
