Old 11-18-2003, 12:07 AM   #1
Scrub
Collector of rusty Items
Scrub's Avatar
Correct me if I'm wrong
I was cruising e-bay and saw this np205 which is supposedly out of a 73 chevy. It's divorced.. I say it's a Dodge, it even has Dodge u-joints.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2442900520
OK I'm bored, but I never heard of a 73 CHevy with a divorced case.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 11-18-2003, 02:07 AM   #2
stan79chevy
stan79chevy's Avatar
i dont think it is factory
i have seen them divorced in chevys but not from the factory but i may be wrong it happened once befor many many years ago
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
Old 11-18-2003, 02:16 AM   #3
ZOOMY
divorced
I"m probably wrong, but I saw one once on a "3 on the tree" truck with a divorced xfer case. Maybe it was a special order order or a hybred.......Zoomy
ZOOMY is offline   Reply With Quote
Old 11-18-2003, 02:21 AM   #4
1969 GMC
1969 GMC's Avatar
all the 67-72 and 73-76 C/30 Napco 4x4 conversions I've seen have had divorced NP205's. If that's the 'case' (pun intended), then it would make me mad someone would just strip a potentially valuable Napco conversion of its transfer just cuz it was a 205.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 11-20-2003, 01:07 AM   #5
kwmech
I agree about the dodge u-joints, chevrolet had/has u-bolt style yokes not strap style. Plus I have never seen a divorced 205 in the later years in a chevy, what the seller needed to do was show a close up of the tag
Old 11-22-2003, 12:12 AM   #6
sakohntr
sakohntr's Avatar
i have
I have a 73' with a 3 on the tree (rare), and it does not have a divorced 205 TC. I have never seen another 3 on the tree truck of this vintage although there supposedly out there. This was a county truck originally. It is now parts.
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
Old 11-24-2003, 10:22 PM   #7
blaz72
You guys sure its not a ford case they use divorced cases.
blaz72 is offline   Reply With Quote
Old 11-24-2003, 11:19 PM   #8
Scrub
Scrub's Avatar
Ford Drivelines are on the drivers side. Dodge and Chevy are on the passenger side. I have a t-case out of a Dodge that is identical to that one.
I don't think any animals were harmed in that e-bay auction, just sort of an anal retentive report on my part
Scrub
Old 11-26-2003, 02:53 PM   #9
JJFRANKIS-72
Question
SCRUB
WHAT IS A DIVORCED T-CASE? THANKS ON ADVANCE
JJFRANKIS-72 is offline   Reply With Quote
Old 11-26-2003, 03:47 PM   #10
Scrub
Scrub's Avatar
A married t-case is bolted directly to the transmission via an adapter and has a splined shaft or collar for an input.
A divorced t-case has a u-joint for an input and has a short driveline between the tranny and the tcase. It is an older style, but does have some advantages in that you can use any tranny that will can fit on your bellhousing. I want to use a wierd NP542 5 speed tranny that has no adapter to a t-case. I can do this because all I need is a driveline that fits the tranny on one end and the t-case on the other end.
Hope this answers your question.
Scrub
