![]() Join Date: Jan 2010
Is this a Drain plug in my torque converter?
I opened up my new torque converter box today and found this plug on the converter. Is it a drain plug or what would this be for? Never seen one like it before. Anyone else have something like this on their converter? I'm hoping it was balanced with the plug in it.
Re: Is this a Drain plug in my torque converter?
Looks like a drain plug and also looks like someone rounded off the head of it.
1985 C10 shortbed, current project. Member of the Upstate SC GM Truck Club. |
![]() Join Date: Dec 2009
Yes.
I have had a few convertors with a drain plug in them.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
That's a drain plug! Typically used when doing a fluid change.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
Ok thanks. The head is not rounded it just appears that way in the pic
Specs on the converter?
I too had not seen one with a drain plug. Curious that. I would want to manually spin the motor around a few times after install to ensure it isn't contacting anything. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
Who Changed This?
![]() Join Date: Jan 2013
I've seen where some transmission shops will open a hole when doing a rebuild, to get the converter nice and clean. They usually put in a small plug that uses a hex key, and is about the same mass as the metal that was removed from the converter shell. MOPAR used to have plugs in their converters, back in the day.
It doesn't contact anything. I spun it already. I don't want to change it as it was probably balanced with it in. It would have been nicer with a Allan key plug but it works.
