![]() Join Date: May 2015
Sway bar 1995 2 door Yukon
I currently have a 1995 2 door Yukon with a 2” torsion lift on the front and 2” blocks on the rear. I would like to minimize the sway as much as possible. It has a factory sway bar but I am looking for improvement. I primarily use this truck for over the road driving not for off road use. Does anyone have any suggestions for an upgrade?
Thanks |
Re: Sway bar 1995 2 door Yukon
The factory one is hollow. The Dorman replacement is solid. It made a big difference on my K1500. The part number is 927-101
Thank you for the feed back. It looks like belltech makes a front and rear kit but it sure if it’s worth the extra money. So the Dorman would be the factory replacement?
Yes the Dorman is factory replacement. When you feel the weight difference between the two it's funny. There isn't much to the OEM one.
| Bookmarks |
