Old 10-04-2018, 03:32 PM   #1
Crabass
Like I need another project
Ok guys, counting on you masters to keep me pointed in the right direction.
Starting another project-----'87 R10 short bed, 4.3/TH375. Been rotting out back waiting for a supposed buyer to collect, for something like two years. Well, time to acknowledge that isn't gonna happen, so time for plan B.
Just happen to have a spare Gen V 454 needing a new home, and as luck would have it, a hydraulic bell housing with all the plumbing, collecting dust as well. A 454 / 5-speed in that truck sounds like some fun. That, and the fact that it won't have a bunch of computers telling me when I can scratch my, well, whatever, makes this project irresistible.
So I'm needing advice on which pedal assy I need to hunt down. The b/h, master/slave, reservoir & line all came out of a '85 one ton. So far I've located a hyd clutch pedal assy from a '91 1/2 ton (vac power brake, btw, which is what I want to end up with). Was wondering if that could be made to work with what I already have.
Any and all advice would be appreciated more than I could express.
Crabass is offline   Reply With Quote
Old 10-05-2018, 09:49 AM   #2
wildwilly4x4
Re: Like I need another project
you should be able to use the 1 ton setup, just swap the brake pedal out for a vac brake pedal. Also the studs are in different from vac, but it still fits the same
wildwilly4x4 is offline   Reply With Quote
Old 10-05-2018, 09:51 AM   #3
wildwilly4x4
or swap to hydroboost brakes and put a gigantic cam in that big block!
Old 10-05-2018, 10:54 AM   #4
sweetk30
sweetk30's Avatar
x2 hydroboost brakes . all my truck get it .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
