Old 10-04-2018, 07:54 PM   #1
1998c1500
1998c1500's Avatar
Power steering id
I am trying to replace the idler arm and pitman arm on a 65 c10 with power steering conversion. I am not sure which one to order because I am not sure what year truck the power steering came from and am hoping someone can help.
Can anyone tell from the pictures?
1998c1500 is offline   Reply With Quote
Old 10-04-2018, 08:39 PM   #2
1998c1500
1998c1500's Avatar
Re: Power steering id
Sorry the pics are sideways.
Moog K6131 shows 69-72 and k6143 shows 73-86 for pitman arm.
The idler doesn't look like the one I see on their site. They show 1 that is straight with grease fitting on top for 1965 and the one on my truck is bent and grease fitting is on the side. Newer ones (k6096t)don't have the bar to mount to the frame.
Old 10-05-2018, 01:14 AM   #3
Captainfab
60-66 Nut
It is really impossible to say just what year steering box was used by just looking at pictures. If the pump is any indication, that is a '73+ pump. The idler arm does look a little odd. What I can see of the bracket on the frame it is typical of a '63-'66 idler arm bracket. I didn't think it was possible to change the idler arm separate of the mounting bracket.
Old 10-05-2018, 06:30 AM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Would casting numbers on the Steering Gear Box help?
Old 10-05-2018, 11:25 PM   #5
Captainfab
60-66 Nut
I do not have any reference to look up steering box castings.
Old 10-06-2018, 03:51 PM   #6
1998c1500
1998c1500's Avatar
I will probably just buy both and return the one that looks different. Hopefully I can find them locally.
Old 10-07-2018, 12:06 AM   #7
Captainfab
60-66 Nut
I would have no problem buying either of those those locally.
