10-06-2018, 07:12 AM | #1 |
Am I green
New guy here and need to be educated
Just got a 82 chevy step side and want to put possible 20"s all round and lowered 4|6 , does anyone have this rim setup on their stepside I'm needing all info on the rims and tires that will fit. Also are the tire , rim combo the same on step sides as fleet sides ???? as far as fender room ??? Any info would be great Tires and rims is a lot of $$$$$ without getting it right. |
10-06-2018, 10:23 PM | #2 |
Re: Am I green
Best advice I can give, is get some cardboard. Lots of it. Cut it to size of the rim tire combo you Wana run put it on your wheel studs n check how much clearance you have.
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
10-06-2018, 10:31 PM | #3 |
Post Whore
Re: Am I green
Welcome...
Rim dia is insignificant....the size of the tire (od & width) you want to run is what matters...along with back spacing and rim width
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 10-07-2018 at 08:51 AM. |
10-07-2018, 04:17 AM | #4 |
Re: Am I green
Thanks for your replies
I was hoping that some body on here would have a set up on their 82 step side that had 20's and give me all the details on tires and rims , backspacing , tire size , |
10-07-2018, 09:48 AM | #5 |
Re: Am I green
Welcome.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
10-07-2018, 05:29 PM | #6 |
Re: Am I green
I had some on my 86, it was a fleetside though. I didn't like them, finally got rid of them and got 18's with more tire. Rides so much nicer now. If you do a search on wheels, you'll probably get quite a few threads on the subject.
Here's one, it has several trucks with 20's
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR Last edited by TKCR; 10-07-2018 at 05:43 PM. |
10-08-2018, 11:16 AM | #7 | ||
Re: Am I green
Wheel & tire combo's are based on individual preferences & budgets. Research will suggest 20x8 - 8.5's up front will work w/o issue. Steppers are notorious for limited rear fenderwell clearance. I know some have squeezed 20x9.5's but they needed to really nail down back-spacing (BS). So here's where preference & budget turn the discussion..... Some drops require rubber band sidewalls while others allow moderate. Some guys are obsessed w/the drop amount & opt to run 'whatever will fit' to be the lowest truck vs doing some sort of compromise that gets a nice drop w/some decent sidewall. Then there's the entry price point 'on the shelf/in stock' CAST wheel choices that come w/limited BS options vs. billet aluminum wheels w/more specific BS options. More BS options allow better (more precise) placement which can lead to more tire size options. Which category are you?
10-08-2018, 07:24 PM | #8 | |
Re: Am I green
This is the reason I'm asking these questions , to figure out what my needs are and what will fit my step side . I do want the 20's and for price , I'm in the middle bracket for what I want to spend Thanks again |
10-09-2018, 09:24 AM | #9 | |
Re: Am I green
The nice thing about steppers in my opinion is the ease of 'modding' for additional clearance in the rear if desired. Some measuring/trimming, some fleetside wheel tubs bolted in, & boom..... more room. There's more to it but it's do-able. Stick w/a tire sidewall as close to or greater than 4" tall for better ride quality (a 245/40-20 would be as short as I would go up front). The taller the sidewall, the better the ride should be. You mentioned a planned 4/6 drop (mild). Mild drops can handle a ~28" front/29-30" rear tire w/o much (any) issue. More drop or taller tire in front will start to yield clearance problems w/factory inner wheel wells.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-09-2018 at 09:33 AM. |
10-09-2018, 12:00 PM | #10 |
Re: Am I green
TKCR - what size tires are you running on your 18"s? All the 18" tires I could find which were taller were mostly offroad style tires, where the 20" ones are more car/street tires.
10-09-2018, 04:53 PM | #11 | |
Re: Am I green
Tires are Pirelli's 265/65/18 all around. They are an All Season tire, Scorpion Verde. Old set up was, 20x8 255/45/20 front 20x10 285/50/20 rear
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
10-09-2018, 07:54 PM | #12 | |
Re: Am I green
Thanks for your input, great help Have my eye on the Ridlers 695 chrome |
