Old 10-06-2018, 04:02 PM   #1
Zone47
Zone47's Avatar
Exclamation Do these rear springs make my truck look fat?
You see, I wanted to jack the truck up a little bit. It had some whimpy 2" drops in the rear, so I found these moog load levelers for like $25 in the Summit Racing bargain pile (just down the street from me and I figured they would jack the rear up about 2" but instead they pumped it up 4".
So that's cool, I like it riding high. So now I'm thinking I need to crank the front up about 2" and everything will be cool.
So does it look fat or doesn't it??
Zone47 is offline   Reply With Quote
Old 10-06-2018, 04:24 PM   #2
dfwright
dfwright's Avatar
Re: Do these rear springs make my truck look fat?
If you do end up going 2" up in the front, please post a good side picture. I'd love to see it. I have stock springs in the back and front on mine, and there's a pronounced rake. I often wondered what it would look like if I raised it 2" in the front. I'd also like to hear how you went about it, if and when you do.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 10-06-2018, 06:51 PM   #3
Zone47
Zone47's Avatar
Yeah, I'm looking into Moog springs and it depends on spring rate and spring load, there are a few that should give it 1-2-" lift... I'll let ya know.
Old 10-06-2018, 06:56 PM   #4
Red71gmc
"Do these pants make by butt look fat? No, your butt makes your butt look fat"
Al Bundy's reply to Peg I believe???
Red71gmc is offline   Reply With Quote
Old 10-07-2018, 02:23 AM   #5
supercheyenne
Those springs should settle an inch or more in a couple months of daily driving (say 2k miles?).
supercheyenne is offline   Reply With Quote
Old 10-07-2018, 09:13 AM   #6
Zone47
Zone47's Avatar
That's good, they'll be perfect by then. Maybe I'll put a little weight in the back too.
The answer is always no, no matter what... !! Why nooo honey, they look fine!
Old 10-07-2018, 11:12 AM   #7
Jason Banks
Jason Banks's Avatar
Are those the Moog 6101 or CC603 part number springs?
Jason Banks is offline   Reply With Quote
Old 10-07-2018, 11:26 AM   #8
notsolo
notsolo's Avatar
I also think a little weight in the back will smooth out the ride and your stance will be look just right.
notsolo is offline   Reply With Quote
Old 10-07-2018, 01:36 PM   #9
Zone47
Zone47's Avatar
They are CC603. 6101 would actually be better but what the heck, $25 was worth the experiment.
Old 10-07-2018, 02:23 PM   #10
Jason Banks
Thanks for the info. I was looking at the Moog website and it shows the installed height on the CC603 is 10.75 inches and the installed height on the 6101 is 8.75 inches. The CC603 is a 'variable rate' spring and the 6101 is a more stock type spring.
I'm personally kind of disappointed because I have a set of the CC603 I haven't installed yet and don't really want my truck to sit up higher. The good news is I got them Amazon as Used, they packaging was just a little banged up. Maybe I could get a 2" lowering block?
Old 10-07-2018, 04:58 PM   #11
Husker
Husker's Avatar
Nice truck
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 10-07-2018, 09:30 PM   #12
Zone47
Zone47's Avatar
Yeah a lowering block would be good. Actually I think the 6101 is for a 3/4 ton, the 6082 might be more what you want if yours is a C10. Spring rate is lower (722) and load is a couple hundred # lower too 2406. Install height is still 10" but that's going to depend on how heavy your front end is.
6082 3.68 0.75 722 2406 10 13.18 TG PT
Old 10-07-2018, 09:57 PM   #13
Jason Banks
It looks like the 6082 is for the Front.
Old 10-07-2018, 11:13 PM   #14
Your huge picture sure made your post fat. I had to shift right and left like a typewriter just to read it . So you had 2" drop coils on, so going to stock would raise it 2". But you used coils that are intended to not drop as much as stock coils when weight is added which can mean they raise it a bit over stock, or at least the weight of the empty truck would not affect the stance. I'd think you'd have to add more than a little weight to make it lower since they are designed to not drop under load. Hence the name load leveler
I don't think they'll settle for many years to come. Do all new vehicles sit an inch lower after a couple payments? Anything I have put lift, stock, or lower springs on sat the same as the day installed.
Old 10-07-2018, 11:17 PM   #15
Zone47
Zone47's Avatar
Unhappy Re: Do these rear springs make my truck look fat?
Yeah, sorry I've been burning the candle at both ends
Well, it's probably good to refresh springs all the way around, so we'll leave it at that.
