Old 10-06-2018, 05:20 PM   #1
bbluma
L33 5.3 Oil pan for '66 Stepside
Hey yall, so am getting ready to LS swap my '66 stepside, and have confused myself with oil pans. lol so i know Holley 302-1 and 302-2 work, but well holley is expensive. So trying to find an F-Body pan that works.
Is there a certain brand, or pan that people are using, if so, is there a link to it?
Or any links to good F-body pans would be appreciated.
Thanks.
bbluma is offline   Reply With Quote
Old 10-06-2018, 10:22 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: L33 5.3 Oil pan for '66 Stepside
Is your truck lowered at all?
Mine is lowered about 4” front, spindles and springs, I have the truck pan and I have no issues with clearance. Hangs below cross member about 1.5” or so.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-06-2018, 10:33 PM   #3
mongocanfly
Post Whore
mongocanfly's Avatar
I just put a c6 pan on mine...it was the shallowest of the factory pans...about 4-3/4" deep...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 10-12-2018, 06:10 PM   #4
UniqueOdyssey68
UniqueOdyssey68's Avatar
I just did a pan swap, mild 4 inch front drop, 60/17 tires. Went with the GMPP "H3/hot rod/muscle car" pan kit. $200 shipped fast from Summit
Comes with everything needed, simple easy swap. Hangs down even with cross-member, plenty of ground clearance, clears top of cross-member with room to slide fingers underneath.
Keep in mind any bolt holes on pan that may or may not line up with your tranny bellhousing bolt holes. 1 didn't on mine, but I'm ok with that, others bolted up fine. Pics in recent post in my build thread.
Or going with an F body pan should be fine, just be sure to get all the parts - windage tray, p/u tube, seals, gasket etc.
I have '06 L33, only 86k miles . The L33 is awesome
- long term project '68 C10 true shortbed! Resto-mod. LS swap. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=769919 "I've still kept this project truck when anyone else would've given up and sold it as is. Giving up is easy, staying the course is part of life's journey"
___________________________________________
'68 C10 true shortbed, LS swap restomod. '03 Z71 daily, '63 AMC Rambler V8 survivor
UniqueOdyssey68 is offline   Reply With Quote
Old 10-16-2018, 10:24 AM   #5
verdell
verdell's Avatar
I swapped an L33 from an '05 Silverado, with BTR Stage III cam, LS6 blue beehive springs and Speed Engineering Headers. With 2.5" drop spindles and the torsion bars turned down a bit, I was more comfortable with the F-body pan also as it sits above the cross member.
verdell is offline   Reply With Quote
