rear bumper help
Hey everyone. I have a 1984 c20 and I have the old big heavy rear bumper and I was wanting to get a new chrome smoothy for the back... But I still want to have my tow-hitch for pulling my trailers. So will I need new brackets and new tow package?
Thank you for your help!
] ![]() 02' f350.7.3 00' F250-powerstroke 00' Roadstar 84' Eagle model 10 72' GMC 18' camery 12' ZX14R- |
#2 | |
Re: rear bumper help
Going to a smooth chrome 'sport' style bumper will require the under truck mounted hitch/receiver style set-up.
It has the hitch/receiver. So therefor I will have no problem with getting the smooth right?
Most standard aftermarket hitches mount under the frame. The receiver tube + ball mount are usually located completely under the plate opening on the bumper.
You can research a hitch set-up for a Suburban, Blazer, or C10/20/30 w/the optional 'Sport' bumper. This could possibly provide measurements that you can compare to what's currently under the truck. Once you know/compare those numbers, as long as the ball mount is under the plate, the Sport bumper should swap w/o issue. I have a 'hidden-hitch' set-up under my CC Square-body dually. It keeps the receiver tube tighter/closer to the frame which puts the ball mount positioned directly behind the license plate. I prefer the hitch tucked & out of site when not being used. I simply flip the plate up out of the way when I need to install the ball mount to tow the trailer.
ok thank you ill do some looking around.. Here are a few pics of mine.
That shouldn't be an issue.
awesome thank you!
thats a factory style or even o.e.m unit on the back .
you are looking for a sport rear bumper style like blazer & suburban all used and some trucks . there the same bumper but specific brackets for each frame style . i got mine off a 2wd c-10 suburban and only needed inner middle brackets . the outer ones were the same . bolted right up to my c-10 pickup . made my own hidden hitch to hide all of it up in behind the flip down plate setup .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
Truck looks good sweetk30.
