Dana 60 Axle?
Hello together,
i own a 1965 GMC truck but i'm not sure if it is a 1500 or a 2500. The brakes in the rear are 1500. The seller told me it is a 3/4ton (2500). I'm confused ![]() Now i need help please with the axle. I think it is a Dana 60. I do a frame off restoration and at the moment i'm repairing the bearings of the hub/wheel. I've ordered TIMKEN bearings (28678/28622 and 18690/18620) but i have problems to find the right bearing seal. The inner diameter of the seal is 60mm (2,36 inch?) and the outer Diameter of the seal is 98mm (3,85 inch ?). here you can find some photos ![]() Greetings from Austria ![]() ![]() ![]() ![]() ![]() |
Re: Dana 60 Axle?
Here are more pictures of the axle
Re: Dana 60 Axle?
By the way: that's the current state of the back of the truck. Completely derusted and painted
![]() I also remade the fixing of the leaf springs (screwed instead of rivets because they were damaged) + 2" lowering shackles ![]() ![]() |
Post Whore
![]() ![]() Join Date: May 2015
Re: Dana 60 Axle?
This is your axle number...
And the axle is 3/4t... Any decent parts store should be able to get those seals...if you clean the seal really good there may be numbers on it...if a parts store cant help you ,then go to a dedicated bearing and seal type store.. That frame turned out nice!!
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 10-07-2018 at 09:27 AM. |
Re: Dana 60 Axle?
1960-1966 GMC: 1000 series=1/2 ton, 1500 series= 3/4 ton, 2500 series = 1 ton. Your VIN# will show this as well. Leaf springs and Dana axles are further evidence of quality features built into standard 2WD GMC's
Re: Dana 60 Axle?
You both are the best
![]() Confusion is gone With the right words (C20/1500) i found the seal National 455860 Many thanks |
Re: Dana 60 Axle?
One question. Is it necessary to put grease into the bearings or is the fluid of the differential enough?
Re: Dana 60 Axle?
Put a little rear axle lube on them when they get installed, then fill the hub as much as possible before installing it. (Or you can install the hub onto the spindle & fill it from the outside before installing the outer bearing cone & axles)
After you're finished fill the housing in normal fashion. Then when you get the truck running, drive the truck over into a shallow ditch to let the lube flow into each hub. Do this left & right sides. Then check & top off the lube level again. You're done! ![]() |
Re: Dana 60 Axle?
Hi,
the axle is clean, painted and mounted in the back ![]() Two question I have on mounting the hubs. I hava a full floater axle with an inner adjusting nut, a thin spindle washer (Dana 30637) and the outer nut. Have sombody torquing infos for a 1965 GMC 1500? That would be great. And is it right to bend the ears of the washer over the outer nut? Thanks in advance Tom |
