Old 10-07-2018, 11:32 AM   #1
tsmith8
New stock Front Leaf Picture?
Does anyone have a picture of a new(er) set of front leaf spring installed on a 55-59 truck?
I am looking at my truck and trying to figure out what i want to do in regards to the suspension this winter and thought i might install lowering springs. Best i can purchase is 3" lowering in the front.
I wanted to look at a pic to compare to my current set to see how much it is actually going to make a difference. Not sure how much mine have already sagged with age.
If mine have sagged 1" in last 60 years then with the 3" lowering springs i would really only get about 2" drop.
tsmith8 is offline   Reply With Quote
Old 10-07-2018, 01:17 PM   #2
Foot Stomper
Foot Stomper's Avatar
Re: New stock Front Leaf Picture?
You're math is correct in that if it's down an inch now, a new lowered spring pack would only be 2" lower.
Check Kijiji for an ad in Ontario for a 3" lowering I beam. He seems to have them figured out for sure. This option will give you another 3" drop with your existing springs and all your factory bits bolt on.
I have a 59 that has stock suspension so if you want some specific pictures, I can help out.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 10-08-2018, 10:21 AM   #3
tsmith8
Thank you. Is it possible you could post a picture similar to this one?
As you can see there is little to no arch on these springs. Thanks again, appreciated.
Old 10-08-2018, 02:53 PM   #4
Foot Stomper
Passenger side. Hope this helps.
Old 10-08-2018, 03:22 PM   #5
tsmith8
Yes that does help. If i had to guess i would say we have about 3/4"-1" difference.
Old 10-08-2018, 03:56 PM   #6
Foot Stomper
Don't guess, measure from bottom side of frame to top of leaf pack, directly above the axle. I measured mne at exacty 5".
Old 10-08-2018, 09:26 PM   #7
tsmith8
I measured both sides. I have 3 3/4”. Bottome side of frame to top of leaf pack. So I have a difference of 1 1/4”.
A three inch drop spring will only give me a difference of 1 3/4” lower.
Old 10-08-2018, 10:18 PM   #8
Foot Stomper
Unless you buy the 3" drop spindle from Captain Hairless.
Old 10-09-2018, 08:01 PM   #9
Foot Stomper
Here's the Kijiji ad.
https://www.kijiji.ca/v-other-auto-p...ationFlag=true
Old 10-11-2018, 02:49 AM   #10
nail pounder
nail pounder's Avatar
My old springs we're pretty flat too, so I did a 3" drop axel, new King pins, tie rods and drag link. Pulled 4 leaves out of the rear and added drop shackles.
nail pounder is offline   Reply With Quote
Old 10-11-2018, 10:36 AM   #11
tsmith8
Did you have to modify anything when installing the three inch drop axle? Did you replace the front leaf springs at the same time?
Old 10-11-2018, 12:05 PM   #12
nail pounder
I did not modify anything and I used the existing old flat leaf springs. If I go any lower I would need to bend the steering arm for the drag link to clear the axle at full left lock. I used Sid's drop axle. He does modify the tie rod connection to come up rather than down so the tie rods won't interfere with the leaf springs. I also had him install new King pins. I mailed my axle to him, he mailed it back 3 weeks later and I bolted it in after work on two afternoons.
Old 10-11-2018, 12:06 PM   #13
nail pounder
I replaced u bolts and added 4 degree shims per Sid's instructions.
