Two 4 inch spearkers for dash?
I am planning to install two 4 inch speakers under the dash to replace the dual voice coil 4 by 10 in there now. Anyone else tried this? I have door speakers to provide base.
1968 SWB Step Side, Big Block, 4L80E , Running! |
Re: Two 4 inch spearkers for dash?
I did that on my 64 impala I installed 2- 4" infinity cappa speakers on a 1/2 plywood base and wrapped in black fabric.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Re: Two 4 inch spearkers for dash?l
I just did this on my Dad’s ‘70 442 convertible. I fabbed a plate up with 20 gauge steel painted it black, mounted in 2 kicker 43dsc44’s and mounted it in place of the factory single speaker. It sounds way better than a single replacement speaker but not great.
It wouldn’t be any harder for our trucks. In my truck I am doing 6.5s in the kick panels, because you can only expect so much sound out of 4in speakers. |
2 kicker 43dsc44’s, Those are the same speakers I bought to do mine. Hope they are louder than the dual coil speaker. My truck has 6 by 9 's in the door panels, I am going to use for woofers.
I used 2 5inch Alpines for the dash, had to fab a frame, pretty easy, and a powered 8inch woofer under the seats. Sounds nice.
'64 C10 LWB, 283, 5speed '68 C20 LWB, 327, 4speed '69 C20 Custom Camper Longhorn, 350, 4speed '72 C20 Cheyenne Super, 396, TH400 '66 C60, 292, 4speed |
![]() Join Date: Aug 2018
I squeezed in a pair of Polk Audio MM461P under the dash still deciding if I want to add speakers to the doors or kick panel with a sub under the seat.
Doug ![]() 71 Sierra Grande C25 16 Sierra 2500HD All Terrain 23 Chevy Tahoe Z71 https://paypal.me/digdug7131?locale.x=en_US |
Post Whore
![]() Join Date: Feb 2016
I used a pair of 3" x6" speakers in my Burban. I liked they way they had more cone area lined up with the speaker slots than a pair of 4" speakers.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
There are several threads on this in the audio section of this website. Do a search there. They show how to make mounting plates, attach, wire... Everything.
Old member
Here is a link several of us have installed speakers and show what we did.
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=607314
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I got lucky and found a pair of '67 rust free doors in excellent shape no one else wanted because they had 6x9 ovals cut in the door.... for cheap! Saved me from having to ruin perfectly good doors
![]() I also bought a pair of '72 scroll door panels someone had installed 6 1/2s in for next to nothing...with speakers for dirt cheap. I'll just set my originals off to the side for if and when being purely original matters. I like good sounding music. I'll probably just go 3-way, but if I go component the speakers in dash would be a good idea. I had a nice '72 door for sale at a swap meet with one rust spot in the lower rear corner (for cheap). Guys would look at the inside and say if it wasn't for the speaker hole they would have taken it. I don't get that. No worries over the rust repair required but curse that bedeviled speaker hole that would be so much easier to repair. Holes on the dash would be easy to fix... on a restoration.
Old member
![]() ![]() Cut them doors and lower them trucks and put late model engines in them but you better not cut that dash man! If you do you just killed that truck! ![]() ![]() ![]() ![]() ![]()
I have 2 x 4" speakers in place of the factory 4 x 10. I used a piece of plywood for the base. Used some stick on weather stripping around the edge so I could press it up against the dash. I used the bracket from the original speaker to hold it in place. I think the mounting is still kind of rigged, more balanced in place with zip ties.
It's being powered by a 70's tape deck I got at a swap meet for $5. I am really happy with how it sounds. By no means great, but it works, gets decently loud, has some bass to it. Best off all, I built it out of spare parts, and didn't have to destroy any factory parts to get it installed.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
#13 |
Hey, the PO of my truck actually cut 2 - 4x6 speaker holes in the dash! I didn't find that out till I pulled the glued on dash vinyl that extended over the pad
#14 |
Would two 4x6's fit and do better than two 4" round? I have an old Kraco deck in mine and someone has put bookshelf speakers under the seat.
Stupidity was meant to be painful! |
#15 | |
Old member
![]() Quote:
I remember reading your post on that one! ![]()
#16 |
My setup. Not great, but it works well. I think the piece of wood on the bottom is zip tied to the factory bracket and there is no connection between the speakers and the bracket. It is just holding it in place. Stick on weatherstripping around the edges for a tight fit.
