Old 10-08-2018, 02:45 PM   #1
scoobiedoo01
LS swap with PSI wiring harness
I'm in the middle of installing the wiring harness from PSI into my 67 C10. Running a L92 with 6L80 trans. My main question is which wire do I tap into behind the ignition switch on the dash that would go with the Ignition Feed wire from the PSI wiring? It calls for 12v in start position and also in accessory but no power when off. Does anyone have a picture of the exact wire from the back side of the switch where the wires come out?
Thanks much!
scoobiedoo01 is offline   Reply With Quote
Old 10-08-2018, 03:13 PM   #2
Low Elco
Re: LS swap with PSI wiring harness
I used the big purple. That's the excite to the starter. Pick it up after the Neutral Safety Switch on the column, if you have an Automatic.
Low Elco is offline   Reply With Quote
Old 10-08-2018, 03:32 PM   #3
scoobiedoo01
My truck was originally a 6 cylinder manual 3 speed on the tree. I do know I need to add a neutral safety switch but didn't come with one.
Old 10-08-2018, 06:32 PM   #4
ls1nova71
ls1nova71's Avatar
I'm sure your harness came with an ignition relay, right? If it didnt you will need to add one, but if it did, then you will turn that relay on with the wire that originally went to the coil. The pink wire in the top of the pic.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 10-09-2018, 10:04 AM   #5
scoobiedoo01
Okay. That was the wire I had figured but good to confirm it.
Thanks much!
Old 04-06-2020, 01:16 AM   #6
sportfish69
Where did you go thru the firewall with your harness?
I will be adding vintage air system and don't want to cut a hole in the wrong spot.
sportfish69 is offline   Reply With Quote
Old 04-06-2020, 01:27 AM   #7
scoobiedoo01
I went through the fire wall in the existing clutch rod hole since I was converting to an automatic and wouldn't need that spot anymore. Worked out perfect.
