Jerry can holder
Have the Swing Away tire carrier and the bracket for the Jerry can. I need a couple other pieces to complete it pictures attached. Anyone has some let me know appreciate it thanks
Re: Jerry can holder
All you need now is an amp and a sub !!
clever idea, I like it! not sure what pieces you need, but lots of jerry can accessories available out there!
https://www.ebay.com/bhp/jerry-can-holder good luck!
I started out with nothing - and I still have most of it |
#5 | |
The hold down you have pictured doesn't look like mine. Mine has a bolt that comes up from the bottom and through the slot in the holder. Then a "C" shaped piece of metal that also has a slot in it goes on the bolt. Then a threaded and bent piece of 1/4" steel threaded 1/4"-20 becomes a wing nut. Should be able to fab it up fairly easy. Probably easier than finding one to buy...
#7 | |
I'll try and get one this week for you.
Sorry for the delay, the weather has sucked. The bottom of my carrier is just a lip that the can sits over. So it may be different from yours not sure. But the hold down would be easy to make. I'm pretty sure Bestop the manufacturer of this one, and it has been on my truck since at least 1990.
Note, the big nut in the picture of the hardware is not part of the kit. The aftermarket can (which is really a flip top toolbox) is not as tall as the original GI cans so the nut is just a spacer to get the wingnut (Just a drilled and tapped piece of bent 1/4" strap) high enough to be tightened without it hitting the tube.
Thank You
| Bookmarks |
