Old 10-08-2018, 10:28 PM   #1
cerial
cerial's Avatar
1987 v10 rear u joints
My 31 year old beast with like 104k is still rocking it's stock u joints with the plastic stuff inside.
So when I torch these things to have the goo squirt out and hammer on the inside of the cap to pop off the caps out of the yoke I replace them with u joints that have outer clips right?
There is a ridge hiding in there for outer clips?
Thing is just a driver and mostly stock doing the joints as preventive maintenance before the snow flies. Doing the brakes next month and then doing the floors before it gets to cold then done for the year.
I want everything laid out to make this hour job a hour job. I am tempted to get outer clips and inner clips then just return the inner if they turn out to not be needed. But think there is a ridge in there for outer clips.
What are you guys using for u joints?
1991 Metro commuter
1991 s10 future project truck
1987 V10 backup daily/junk truck
1985 K20 Winter beater
1991 R30(squarebody) c/c flatbed towrig
1994 s10 80"wb custom build
cerial is offline   Reply With Quote
Old 10-08-2018, 11:31 PM   #2
Zachary17
Zachary17's Avatar
Re: 1987 v10 rear u joints
I just did my slip yoke joint today.Mine has a 1 piece drive shaft.and both the joints use the same u joint.the ones i used are moog super strength part# 235 got them form summit racing.thay also use inner clips to hold em.
Zachary17 is offline   Reply With Quote
Old 10-09-2018, 03:43 PM   #3
sweetk30
sweetk30's Avatar
heat up the yoke area around the cap untill plastic is all squeazed out . you DO NOT have to make the whole thing glow orange . also watch your self wear safty glasses . the plastic can POP .
let the whole shaft cool down .
service the u-joint like normal .
remove the old plastic from the yoke when the cap is removed .
take a flat file and clean the snap ring seat area from any rust and junk over the years .
install new joint and clips that come with it .
before install hold the caps on the axle end and wack the yoke each side with a hammer to free up tension from cap install . flex the joint before and after . you will feel a difference . wack the other end yoke areas for the caps also .
then grease before install and install the shaft .
also tip make sure the grease fittings are in line for easy service and i like them to point to the center of the shaft also .
if non greaseable then skip last tip .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 10-09-2018, 04:31 PM   #4
andyh1956
[QUOTE=sweetk30;8360513] also watch your self wear safty glasses . the plastic can POP .
This is the most important part of sweet's post!
He aint kiddin!
andyh1956 is offline   Reply With Quote
Old 10-10-2018, 09:08 AM   #5
cerial
cerial's Avatar
So it is definitely inner clips. No recess in the yoke for outer clips?
1991 Metro commuter
Old 10-10-2018, 12:22 PM   #6
sweetk30
sweetk30's Avatar
should be . the new u-joints come with clips in the box .
