tommy . master of madness
Help!!! Big Trouble In Ohio
![]() ![]() . ![]() ![]() tom ![]() |
![]() Join Date: Mar 2000
Use the 87 parts, be sure to save your original center link as they are not made new and someone most likely will need one on the parts board. You could use just the 87 outer tie rod ends but then you would need a adapter sleeve to attach the larger 87 outer tie rod to the smaller 67-70 inner tie rod. Since you already have the 87 parts cheapest route is to reuse the 87 parts.
GMCPaul |
