Before and After
Seat Belt Install location
Does anyone have the rough measurements to locate the retractable seat belt by the door?
During repair of the cab, I replaced the metal that houses the threaded insert for it. any close measurements will help. I will install a reinforcement plate when installing it now. This is what I have to work with now. The red circles are the rear seat mounting area.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
![]() Join Date: Jan 2017
Re: Seat Belt Install location
I have one hole. 6 1/2" from back of cab x 1 1/2" from door seal area. Door seal is actually forward of the hole. I think this is what your asking and helps.
Before and After
That is a great start Thanks
How did I get this OLD!
![]() Join Date: Dec 2014
Hope this helps. I’m in Edmonton area so you can PM me if you need actual measurements.
http://67-72chevytrucks.com/vboard/a...1&d=1539225758
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
