![]() Join Date: Dec 2004
Stock wheels
Just picked up a 1953 3100. I’m looking for wheel options that look like the stock 16” wheels.
1972 c10,2wd,long bed,250,4spd----> 1972 SWB Fleetside 4x4 12v Cummins build thread http://67-72chevytrucks.com/vboard/s...d.php?t=513791 |
![]() Join Date: May 2007
Re: Stock wheels
you have a couple options, wheel vintiques makes 16" oem look wheels but you will need to run their caps. you can get them as narrow as 5" and as wide as 10". I get my wheel vintiques wheels from jegs, mostly the artilley type never bought the oem type there, but free shipping that way.
you can also try http://www.thewheelsmith.net/CustomW...cessories.html , he can make anything you want and will modify your hubcaps to fit. I dont think his wheels will use a stock cap either, but I have heard you can send him your wheels and have them rehooped to be wider
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
Re: Stock wheels
Hmm, my main goal is to run stock caps so may be better off running stock wheels. I would like to have other bolt pattern options for ifs while keeping a stock look.
If I do keep stock wheels do I need to run bias tires with tubes?
Re: Stock wheels
I think maybe I said it wrong, let me try again. both wheel vintiques and wheelsmith sell stock looking caps that fit on their wheels. I used the chevrolet caps on my 49 with wheel vintique artillery wheels and they are super high quality stainless.
![]() I tried to use the wheelsmith hubcaps on my 47 GMC (the only guy who makes the stainless GMC caps that fit wheel vintiques wheels) and he wanted $160ea. so I ran just smoothie caps. when I wanted the small caps for my 41, I just got 39 chevrolet script stickers and put them on the smoothie baby moons. ![]() as far as someone who makes wheels that take the clip style caps I dont have any idea on that. I also dont know if you can put a tubeless valve stem in your wheels and run them without tubes. but the wheelsmith guy would know.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 Last edited by joedoh; 10-10-2018 at 06:30 PM. |
#5 | ||
Re: Stock wheels
With that in mind, I have been successfully using tubeless tires on the stock wheels of my '36 Plymouth for at least four years and used tubeless tires on my '57 for many years. Currently I am running horse trailer wheels with stock-ish center caps and modern trim rings. These wheels do not have internal clips. But internal clips are available separately and can be installed with rivets. Last edited by 1project2many; 10-10-2018 at 06:42 PM. |
