Old 10-12-2018, 09:15 AM   #1
jmj4
jmj4's Avatar
Rochester Divorced Choke
Does anyone have a source for a divorced choke for a 2 barrel rochester? They appear to be discontinued. I bought one several years ago but the coil is backward and doesn't work with my truck.
Appears online to be discontinued. Thanks in advance.
-j
1970 GMC Custom 1500 SWB 307/TH350 3.73 Positrac
jmj4 is offline   Reply With Quote
Old 10-12-2018, 10:57 AM   #2
geezer#99
geezer#99's Avatar
Re: Rochester Divorced Choke
Try here.
https://quadrajetparts.com/choke-the...-72_84_99.html
Old 10-15-2018, 02:52 PM   #3
jmj4
jmj4's Avatar
Will do. Thanks.
Old 10-15-2018, 03:10 PM   #4
geezer#99
geezer#99's Avatar
Sometimes you can change the coil position. Depending on how they’re put togethor.
Old 10-15-2018, 03:17 PM   #5
jmj4
jmj4's Avatar
I looked at that. The one I bought appears to have a blind rivet. When installed, the bimetal coil was backward, thus causing it to close the choke the warmer the engine.
Not sure other than drilling out how to remove the coil but may try it.
Old 10-18-2018, 06:33 PM   #6
John H.
John H.'s Avatar
I have a complete set from my 69. It has the cover, spring setup and rod.
I took it off with 33k miles.
John H. is offline   Reply With Quote
Old 10-18-2018, 07:33 PM   #7
External
External's Avatar
https://cliffshighperformance.com/Qu...ke-thermostats
Here is one, less 30 bucks.
External is offline   Reply With Quote
