Old 10-12-2018, 12:08 PM   #1
a1vintage69
a1vintage69's Avatar
nos GM retainer clips tailgate trim and taillight bezel
These are gm nos retainer clips for tailgate trim and tail light bezel trim clips. $3.95 each clip + shipping.
a1vintage69 is offline   Reply With Quote
Old 10-12-2018, 05:13 PM   #2
samkost
samkost's Avatar
Re: nos GM retainer clips tailgate trim and taillight bezel
PM sent.
samkost is offline   Reply With Quote
Old 10-12-2018, 09:38 PM   #3
cst204x4
I'll take the ones on the right
1970 CST 4x4 collecting nos parts for this project
1972 cutlass owned since 1984
1972 cutlass conv
1970 Cutlass conv
1981 chevy shortbox
1986 grand national
2004 2500HD Crew Cab 66,000 miles
cst204x4 is offline   Reply With Quote
Old 10-12-2018, 10:04 PM   #4
a1vintage69
If you want the far right with the foam I have 6 only of that kind. I will pm you. thanks , a1
Old 10-12-2018, 10:39 PM   #5
samkost
samkost's Avatar
Steve, what is the purpose of the foam?
Anti rattle?
I never noticed clips like those 6.
Wondering if it is beneficial for trim installing purposes.
Thanks,
Sam
Old 10-12-2018, 10:47 PM   #6
a1vintage69
Anti rattle?
Thanks,
Sam
Sam, It pushes into the hole with the clip catches and helps seal it. I always run a bead of silicone around my holes after clip is in the hole. .
Old 10-12-2018, 10:50 PM   #7
a1vintage69
Mike, thanks for quick payment! a1
Foam clips SOLD. I have lots of clips left for anybody who needs nos clips.
Old 10-12-2018, 11:05 PM   #8
samkost
samkost's Avatar
Alright then.
Good to know.
Thanks for the info again Steve.
Old 10-13-2018, 06:46 AM   #9
If you have them, I will take all that is required to mount tailgate trim and tail lamp trim. Unsure of the quantity w/o looking into it. 6 for tail lamps?
Old 10-13-2018, 10:53 AM   #10
a1vintage69
Tim, I have 3 different kinds of nos clips and all came in gm boxes or package and have the same part number. The taillights take 4 each side. and the upper trim 3 clips each side and clips that have a screw and nut, I think. I don't have that kind of clip. The bottom trim takes 9 clips. Here are a couple threads worth viewing . I had nos trim and clips and still got a dink when installed.
http://67-72chevytrucks.com/vboard/s...d.php?t=531850
http://67-72chevytrucks.com/vboard/s...d.php?t=705912
Old 10-13-2018, 12:19 PM   #11
PDXk5
PDXk5's Avatar
Hey Steve,
So if I understand correctly, 19 clips will cover upper band (not including the screw type clip required at each end), lower band and both tail light bezels. I WILL TAKE A SET to complete an entire install. Please PM my final cost.
I hope you have enough for me, Thanks!
PDXk5 is offline   Reply With Quote
Old 10-13-2018, 12:52 PM   #12
a1vintage69
Originally Posted by PDXk5 View Post
Hey Steve,
I will let Tim go first . I think I can take care of you too. I need to figure out which clips fit the best on the trim. I used the clips with the with the nub on the back for my taillight trim. but the other style doesn't have the nub. I can't find my nos upper trim to see if either clip works on it. I will get back with you.
Old 10-15-2018, 12:55 AM   #13
John H.
John H.'s Avatar
For what’s its worth, the pile of clips on the far left are exactly like my upper trim NOS clips. There are 4 clips plus 1 with threads that bolts through the end of the tail gate, upper mouldings right and left. The clip with the threads goes on the end of both sides.
The second pile looks like the taillight bezel clips and there are 4 clips per side.
John H. is offline   Reply With Quote
Old 10-15-2018, 06:15 AM   #14
Njeiv
“On The Hunt”
Njeiv's Avatar
I’ll take the clips required to do both sides of tail light trim and both sides of tailgate trim.
Including center (if required)
Njeiv is offline   Reply With Quote
Old 10-15-2018, 09:51 AM   #15
Sending money order today for upper r/l & tail lamp r/l clips for my Seirra
Old 10-15-2018, 10:41 AM   #16
a1vintage69
Nic, couple guys ahead of you. I will see what I can do.a1
Old 10-17-2018, 01:21 AM   #17
a1vintage69
Nic, could not put together a full set of clips. I got ahold of a few contacts and these nos GM clips are up to $6+ bucks each. That's double what I paid them last year for the same clips. I guess I should have bought all of them then. a1
Old 03-14-2020, 09:04 PM   #18
cheyenne402
Still available?
cheyenne402 is offline   Reply With Quote
Old 03-14-2020, 09:06 PM   #19
a1vintage69
Originally Posted by cheyenne402 View Post
Still available?
all sold
