Old 10-13-2018, 02:03 PM   #1
Cristiann8
Fender bolts question
What's the bolt sizes for the front fender bolts to mount it to the cab and core support?
Cristiann8 is offline   Reply With Quote
Old 10-13-2018, 02:14 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Fender bolts question
There are basically 3 different size bolts. Almost all of them are 5/16 x 3/4 fender bolts (a couple are 5/16 x 1 but I can't remember which ones). The bolts that hold the bottom rear of the fender to the cab are 3/8 x 1 with an integral washer and the large bolt for the inner fenders to the lower cab support are 7/16 x2. Those have a large (2 or 2 1/2")diameter integral washer on them.
LockDoc
Leon
Old 10-13-2018, 02:18 PM   #3
Cristiann8
LockDoc
I bought some 5/16 bolts and they were way too loose?
Old 10-13-2018, 02:34 PM   #4
Getter-Done
Getter-Done's Avatar
If you are referring to the top 2 fender bolts that bolt it to the cab they are 3/8-16tpi. One of them is 1 inch long and the other is 1 and 1/4 inch long.Name:  fb1.jpg
The early bird gets the worm,
85 Chevy K-20
Old 10-14-2018, 10:29 AM   #5
LockDoc
LockDoc's Avatar
Originally Posted by Getter-Done View Post
If you are referring to the top 2 fender bolts that bolt it to the cab they are 3/8-16tpi. One of them is 1 inch long and the other is 1 and 1/4 inch long.Attachment 1829235
Yep, I missed those. Thanks for the addition.
LockDoc
Leon
Old 10-14-2018, 12:53 PM   #6
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Mine were:
• The rear top and bottom of the fender use three (GR 5) 9/16" recessed hex bolts with integrated washers. The bolt threads for the LH fender were 3/8-16 x 1.1/4. The bolt threads for the RH fender were 3/8-16 x 1.1/8.
NOTES:
The 1.1/4 bolts are stamped with a double "F". The 1.1/8 bolts are stamped with an anchor.
• Each fender mounts to the gusset & core support using four (GR 5) 1/2" recessed hex tapered bolts with integrated washers. The bolt threads are 5/16-18 x 7/8. NOTE: The bolt heads are stamped "E".
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
