Old 10-14-2018, 09:05 PM   #1
SteveA69
SteveA69's Avatar
Need picture of upgraded fuse panel
Does anybody here have pics of the painless or American wire fuse panel installed from both sides of the fire wall ? Thank you!
SteveA69 is offline   Reply With Quote
Old 10-14-2018, 09:26 PM   #2
dfwright
dfwright's Avatar
Re: Need picture of upgraded fuse panel
I have the AAW classic update installed in my truck. I don't know if this is what you are looking for. I don't have pictures, but I could take a couple if no one has some pictures already made to post for you.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 10-14-2018, 09:43 PM   #3
SteveA69
SteveA69's Avatar
That would be awesome, thank you!
Old 10-14-2018, 11:53 PM   #4
dfwright
dfwright's Avatar
Let me know if you need to see a different view
Old 10-15-2018, 12:10 AM   #5
Getter-Done
Getter-Done's Avatar
That looks good.
The early bird gets the worm,
84 Chevy K-20
Old 10-15-2018, 12:26 AM   #6
SteveA69
SteveA69's Avatar
Perfect thank you!
Old 10-15-2018, 01:49 PM   #7
Andy4639
Old member
Andy4639's Avatar
Question Re: Need picture of upgraded fuse panel
Did you have to cut any more metal out of it are did it fit in the factory opening? Just wondering.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 10-15-2018, 07:43 PM   #8
dfwright
dfwright's Avatar
You have to widen out the factory square hole about a 1/4 inch or or so to fit. The kit comes with a template to mark and cut the hole bigger. Interestingly, the bulkhead connector was made to fit a 1968 GM car apparently, and our trucks had a slightly smaller hole.
"Classic Update Series kits are based on the 1968 and later GM bulkhead assembly which has a different mounting footprint than earlier bulkhead connectors.
Therefore, it will be necessary to modify the firewall of the 1961-1964 Chevy Fullsize cars, the 1967-1968 Chevy and GMC trucks, and the 1969-1972 Chevy and
GMC trucks to accept the 1968 and later design bulkhead"
Old 10-16-2018, 08:26 AM   #9
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Need picture of upgraded fuse panel
I went the cheap route and added another fuse panel beside the factory one.
