Old 10-15-2018, 10:22 AM   #1
Travisarmenta
Travisarmenta's Avatar
3 on the tree to a.....???
Picked up a 70 K10 SWB and want to mate either a 4 speed, or a 700r4. regardless I know I need A LOT.
Which one can I do WITHOUT messing with the NP205?
Travisarmenta is offline   Reply With Quote
Old 10-15-2018, 12:01 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: 3 on the tree to a.....???
If you go to an SM465 four on the floor you will need to change your current adapter between the three on the tree tranny and the N205. It should be very simple to find that adapter. That will be your easiest swap.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-15-2018, 01:45 PM   #3
Travisarmenta
Ok thanks, I will look into that.
Old 10-16-2018, 02:54 AM   #4
I believe Advance Adapters sells that one, if you can't find a used one.
Old 10-16-2018, 12:54 PM   #5
Travisarmenta
Thanks, I might have found a donor: 77 K10, 4 speed with the 205 behind it.
scrap the rusty body and sell the rest. We shall see.
