10-15-2018, 08:24 PM | #1 |
big block 402 engine brackets
Just bought a 402 for my 69 truck don't remember mounting bracket location and engine came with some of them this one has alternator on passenger side i dont think thats right maybe it is
need photos or help so i know what to buy thanks |
10-16-2018, 07:40 AM | #2 |
Re: big block 402 engine brackets
The truck pulleys and mounting brackets are the same as the 65-68 big block Chevelles if you are looking for a source for replacements.
But you are correct, passenger side alternator setup was for the long water pump that was never installed on 68-72 big block trucks. Sounds like somebody swapped a big block into your truck from a 73 and up truck donor or 69 and up car donor.
10-16-2018, 08:09 PM | #3 |
need pictures of ac brackets have the other figured out
10-16-2018, 08:48 PM | #4 |
Google images for 68 Chevelle ac brackets should find it.
10-17-2018, 01:52 AM | #5 |
this is a pic taken from another member...they are the stock 72 ac brackets
10-17-2018, 11:09 AM | #6 |
and the ps and alt brackets
10-17-2018, 12:37 PM | #7 |
10-17-2018, 02:00 PM | #8 |
one more
10-17-2018, 02:03 PM | #9 |
ps brackets
10-17-2018, 08:26 PM | #10 |
10-17-2018, 11:38 PM | #11 |
yes
10-22-2018, 10:40 PM | #12 | |
10-22-2018, 10:41 PM | #13 |
10-23-2018, 09:10 AM | #14 |
It’s mounted to the driver side fender.
10-23-2018, 10:06 AM | #15 |
Those are mine which would make them '70 but I imagine all the same!
10-23-2018, 10:12 AM | #16 |
From a dry run I did. Shows all the brackets. It doesn't show the retainers/clamps near the evap. I have assembly instructions if you need it, down to the bolt type.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
10-23-2018, 09:34 PM | #17 |
10-23-2018, 09:47 PM | #18 |
Found a thread using search box at top of page with check box for this site selected. There are some included that had a bracket from radiator support, but the big block trucks I have owned (70 and 71)have had it like on fender.
http://67-72chevytrucks.com/vboard/s...d.php?t=735249
