Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 10-15-2018, 11:43 PM   #1
1966burb
1966burb's Avatar
1966 CHEVROLET suburban engine question
I want to verify the date on the engine block of the 327 that came out of my 1966 Suburban. Casting # on rear of block is 3858174. The other casting numbers I find are on the back of the block which would be under the flywheel. H5 174. Is this the date or do I need to look somewhere else for the date? Thanks, Jim
1966burb is offline   Reply With Quote
Old 10-16-2018, 12:38 AM   #2
Captainfab
60-66 Nut
Re: 1966 CHEVROLET suburban engine question
The casting date is cast into the block on the passenger side of the block, above where the flywheel is. It does consist of a letter which corresponds to the month of the year, then the day of the month and then the year as a single digit.
Old 10-16-2018, 11:32 PM   #3
1966burb
1966burb's Avatar
Here is a photo of the back of the block. Any ideas on date?
Old 10-17-2018, 12:19 AM   #4
Captainfab
60-66 Nut
That looks like it is behind the flywheel.....I do not see any date code there. The date code is located where I previously said.
This is on a big block but a small block casting numbers and date codes are in the same location.
http://www.67-72chevytrucks.com/vboa...d.php?t=773368
Old 10-17-2018, 01:20 AM   #5
1966burb
1966burb's Avatar
just had to look in the correct spot and scrape off some grease to find it!
Old 10-17-2018, 11:16 PM   #6
Captainfab
60-66 Nut
Does that say B 4 6 ? If so, the block was cast on February 4th 1966. The casting number does show to be a 1964-67 327. What is the stamping on the front pad?
Old 10-18-2018, 10:02 AM   #7
1966burb
1966burb's Avatar
Yes B 4 6 . I will check stamped number on front.
Old 10-21-2018, 10:31 AM   #8
1966burb
1966burb's Avatar
stamping on front reads FO2O9YD
Old 10-21-2018, 08:15 PM   #9
VictoriaHardware
VictoriaHardware's Avatar
So far so good. Block cast on Feb 4, final assembly on Feb 9. At Flint Engine Plant on Bristol Road, which is gone now.
VictoriaHardware is offline   Reply With Quote
Old 10-21-2018, 11:51 PM   #10
Captainfab
60-66 Nut
Here is the suffix code info.
http://www.nastyz28.com/gm-chevy-cod...-suffix-10.php
Old 10-22-2018, 09:55 AM   #11
1966burb
1966burb's Avatar
Thanks for all the information and help. Everything seems to line up good as original engine. J
Old 10-24-2018, 12:34 PM   #12
VictoriaHardware
So YD = Powerglide w/ A.I.R.
Your motor had A.I.R. (smog pump) ? Was it originally sold in California?
Old 10-25-2018, 12:06 AM   #13
1966burb
1966burb's Avatar
It does have the plugs in the exhaust manifolds where the A.I.R. system used to tie in.
