Old 10-16-2018, 03:03 PM   #1
beaterku
beaterku's Avatar
Power Steering Lines
Good afternoon everyone. I am swapping the engine in my truck and was going to replace the the power steering line, but I have run in to a discrepancy.
I am looking at Delco parts 36355230 and 36355240.
Part 36355230 is on the left with with the correct fittings on both ends, but the bends are not correct at the box.
Part 36355240 is on the right with the correct bend at the box, but with an adapter fitting at the pump. I am not too keen on adapters, but the line looks correct other than that.
What is everyone using for replacement lines? I was also going to swing by the local hydraulic shop and see if they can swage a new hose in the middle.
Thanks!
EDIT: Added a picture of my current high pressure line.
beaterku is offline   Reply With Quote
Old 10-17-2018, 06:00 AM   #2
my kids toy
Re: Power Steering Lines
Hyd shops will not be able to cut hose and replace but they can cut the metal tube and use a compression fitting.
my kids toy is offline   Reply With Quote
Old 10-17-2018, 09:56 AM   #3
beaterku
beaterku's Avatar
I'm going to swing by their shop today and see what they can do. Thanks!
Old 10-17-2018, 10:10 AM   #4
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I took my existing hoses (some metric and some SAE) to the hydraulic shop. They cut the ends off and put the braided hose in place of the rubber. So, I have metric fittings on one end and SAE on the other. I was hoping they could re-bend a couple of the hoses for better routing, but they could not. Just make sure you know where you want them to be cut at. I made templates out of wire clothes hangers. They got close, but one of them is about two inches shorter than I would have liked it to be. I still have to have my low pressure hoses made.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 10-17-2018, 10:19 AM   #5
beaterku
beaterku's Avatar
Looks good! Thanks for the info!
Old 10-17-2018, 12:00 PM   #6
Bigdav160
Bigdav160's Avatar
The adapter would be correct for a factory installation. At least it was for my '72 K20.
It looks like you removed the flow valve out of your steering pump. Make sure it goes back in with it's spring. Then install the line.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-17-2018, 12:30 PM   #7
beaterku
beaterku's Avatar
Thanks. Yeah I removed it to swap over to the new LS pump. Now I am messing with trying to figure out replacement lines so it may be a moot point.
