oil pressure
I have an oil pressure gauge but I have no idea what the proper oil pressure should be around. I have a small block 350.
Re: oil pressure
There are lots of variables with those engines, but usually anything over 25psi I would consider safe. I've seen some older 350s idle at around 5-10psi with no problem, though I feel that's pretty low.
14 Silverado- 4/6 drop daily 66 GMC short wide Custom Cab- building to be low and cruise. 4.8/t56 swap occurring now. Stupid low static drop ![]() 66 GMC 1 ton stepside looooong bed- the tow pig/work truck. |
Re: oil pressure
Thanks. Is there a pressure that would seem to high?
![]() ![]() ![]() Join Date: Jan 2018
Re: oil pressure
From what I've read, anywhere between 30 and 80 psi will be good
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
