Old 10-16-2018, 05:41 PM   #1
Nick_c10
Saginaw 4 speed swap
So I can get a 4 speed Saginaw out of a guys 68 C-10 with a B and M shifter, bell housing, and clutch for $400, he says it runs good with no problems. I know they are not the best manual out there but it would be a pretty cheap swap as opposed to a Muncie or Tremec. Is this a good deal and would it hold up to a 383 stroker? I’ve never dyno’d it but I estimate about 400 hp, currently has a 700r4. Thanks.
Nick_c10 is offline   Reply With Quote
Old 10-16-2018, 06:50 PM   #2
Mike C
Mike C's Avatar
Re: Saginaw 4 speed swap
If you drive it more like you are 50 years old than 20 and you don't have any tire under the truck it would probably live. Manuals are a blast no doubt, but you will regret losing your overdrive IMO.
If I was building a beater truck with all Craigslist parts just to see how cheap I could put it together, I'd do it. But I think it's a step backwards from the driveability of you TH700R4 and it's .70 top gear.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-16-2018, 07:31 PM   #3
They can handle 'normal driving'. They can tale a little. Think "They can't take what a Muncie performance transmission can" and you'll be fine. I have one I bought with a van shifter (tall/straight) because it was from a van. I paid $175. I figured that was a good price. Not sure what they're worth.
Old 10-16-2018, 08:51 PM   #4
Nick_c10
Thanks for the advice guys, I think I’ll pass.
Old 10-16-2018, 09:17 PM   #5
Nick_c10
So I passed on the Saginaw and the guy says he has a M21 he would consider selling. I’m not an expert but I read something about a tall first gear, I have 3:73 rear end, would that work?
Old 10-17-2018, 06:58 AM   #6
Yes, will work well.
Old 10-17-2018, 08:45 AM   #7
Mike C
Mike C's Avatar
What are your plans for the truck? I defer back to my other post where if you drive on the highway and want to cruise for any real distance, you will miss your overdrive.
44 Willys MB
52 M38A1
64 Corvette Coupe
