10-16-2018, 09:10 PM | #1 |
cab, less roof, sheet metal pieces
Here is the story. My 67 needed a roof and A pillars and I got this cab just for that as the roof was in great condition. After I cut that off I was left with a cab I have no need for but still has some usable sheet metal for somebody. The floor is pretty solid. There is a bunch of rust in the kickpanel areas on both sides. I thought the cab corners in the rear are bondo covering rust. The rockers appear ok but I would think they are not great and the floor braces are rusty. I don't know what year it is as there is no tag/no title
Price: $75? Only need part of it? Ask! I have a sawzall and cut off wheels and will work with you any way I can. I am in Ventura Ca so obviously you would need to come here as shipping would be more than the whole thing is worth.
10-19-2018, 11:07 AM | #2 |
Re: cab...less roof!
Bump. I don't want to scrap it.
10-19-2018, 10:22 PM | #3 |
Would you be willing to cut this section out? and ship to Niagara Falls NY 14303?
10-20-2018, 10:57 AM | #4 |
absolutely! PM sent.
10-21-2018, 05:43 AM | #5 |
Hello,I have a 72 camper I need a piece of the rear panel from the window opening to the floor .I will post a pic of the area I need .
10-21-2018, 10:50 AM | #6 |
Sounds good. Let me know and I can cut what you need.
10-25-2018, 09:53 PM | #7 |
Pics of the piece I'll be needing
10-25-2018, 10:01 PM | #8 |
Piece needed
10-26-2018, 09:20 AM | #9 |
Could i get prices and shipping for these 2 pieces?
Thank you!
'72 K20 Ochre/white 350/350/205 4" Lift 35's '72 GMC K10 red orange/white 400/350/205 '69 C20 Longhorn 454 TH400 '72 Blazer CST 4x4 '70 Blazer 4X4 |
10-26-2018, 04:50 PM | #10 |
I will check those pieces to make sure they are good and PM you.
10-27-2018, 01:18 PM | #11 |
More pics of the floor areas to hopefully help answer some questions. The floor braces that go over toward the rockers both front and back have rot. In the rear the floor above the rear braces is starting to pucker up and has ate thru a hole I tried to show in the picture
10-27-2018, 09:05 PM | #12 |
So I sent another outline of the panel If you cut the black line I should be all set.
10-27-2018, 09:20 PM | #13 |
Also need this area
10-28-2018, 10:01 AM | #14 |
I could use the opposite side of this cut a little wider and lower. 33511
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
10-31-2018, 09:49 AM | #15 |
Here is what i need in red. Circled in green i would like but can live without.
10-31-2018, 12:31 PM | #16 |
Looking to bet the action on LH firewall from lower seam up to top edge of cowl. Shipped to 95687. See the attached pic of the section I’m needing to replace.
1971 Custom/10 - 350/3 speed, Orange/White roof |
10-31-2018, 12:47 PM | #17 |
Sorry, that part is sold. If it falls thru though I will let you know.
11-01-2018, 07:11 AM | #18 |
Send me a pic of the section? I've got your paypal info.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 Last edited by jjzepplin; 11-01-2018 at 07:58 AM. |
11-08-2018, 09:57 AM | #19 |
Parts arrived yesterday and are exactly what I needed. Thank you!!!!
11-08-2018, 11:16 PM | #20 |
Thank you for your help I appreciate your time and effort.Excellent service
11-09-2018, 04:17 AM | #21 |
Do you still have the hump, pictured what blap posted ? I would take it if still available.
11-09-2018, 11:45 AM | #22 | |
I was very happy to cut out pieces for others to help their projects along. Thank you!
07-15-2019, 01:34 PM | #23 |
Are there any floor board pieces left? I need the floor board section underneath the gas pedal
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 |
07-15-2019, 02:54 PM | #24 |
Its all gone.
07-15-2019, 03:09 PM | #25 |
