10-17-2018, 01:55 PM | #1 |
Squeaky Brakes
breaks squeak when I slow to a stop. Maybe the last 10 mph to stop. Driving me crazy. Easy solution? Take pads off and roughen them up and the routers? Thoughts? Only about 4,000 miles on the pads
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
10-17-2018, 08:35 PM | #2 |
Re: Squeaky Brakes
anti seize/anti squeak grease is your friend always use it.
10-19-2018, 10:28 PM | #3 |
Re: Squeaky Brakes
It’s not the pads on the rotors?
10-20-2018, 09:16 AM | #4 |
Re: Squeaky Brakes
I used to put goop on all my disc brake pads in the old days. That was the only way to keep them from squeaking. Nowadays I never use it since pads already have some kind of spacer on them that seems to keep them quiet. If I had to look at them again due to squeaking I would put the disc quiet stuff on them. Actually the last stuff I bought was aerosol and had a cool smell that reminded me of some toy making goop I used to play with as a kid. I did like the way the aerosol went on though.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
10-21-2018, 04:06 PM | #5 |
Re: Squeaky Brakes
well known as disc quiet stuff, ante squeak, squeak stop, and there one or two more.
anti seize will work on the back will not work as long term/anti squeak grease will work for longer but some times lefts off a little bit has to redone make sure it clean before putting on new stuff. But if the pads are still pretty thick check the wear bracket it maybe bent to close some time they get bent they have be set in the right place. Some where between 1/2-1/4 of the pad. You can set them with a feeler gauge, just measure the new pads put as mean feeler gauges 1/2" they squeak you re check clean and re-a just and then bend wear bracket to 1/4" the next time you hear it should be time to change. But it maybe something else. Look them over well.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
10-24-2018, 08:07 AM | #6 |
Re: Squeaky Brakes
I will tear into it and have a look
thanks Chris
