Old 10-17-2018, 03:12 PM   #1
hotrod 80
mini truck racer
hotrod 80's Avatar
Fuel pump question
I am doing a 2001 Suburban drive train 5.3/4L60E/ 10 bolt 8.6 narrowed into a 1977 chevy Luv . I am having an aluminum fuel tank built to bolt into the factory location . I bought an aluminum fuel pump ring to have added to the top of the cell . May question is can the factory fuel pump be shortened to work with the new fuel cell ? I am installing all the drive train components as is and stock .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 10-17-2018, 03:22 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Fuel pump question
Although not factory, i think holley make an adjustable depth fuel pump...what fuel pump ring do you have?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 10-17-2018, 05:30 PM   #3
ls1nova71
ls1nova71's Avatar
They're spring loaded and will collapse to a given height, but when it stops, if you cut things and go further, you'll start linking the lines. Truck senders are pretty tall, but Tahoe ones are much shorter, may look into one of them.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 10-18-2018, 06:10 AM   #4
hotrod 80
mini truck racer
hotrod 80's Avatar
I'm not sure. It is a factory 2001 suburban. I didnt know there were different rings .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 10-18-2018, 06:12 AM   #5
hotrod 80
mini truck racer
hotrod 80's Avatar
I was trying to keep everything but the harness as stock as possible. This is my first swap and will be leading up to a high end LS swap on my 49
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 10-18-2018, 10:25 PM   #6
hotrod 80
mini truck racer
hotrod 80's Avatar
99-06 small ring
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
