Old 10-17-2018, 04:45 PM   #1
ne72gmc
ne72gmc's Avatar
Inline 6 Heat Riser
Does anyone know where I can get replacement parts for the heat riser in the exhaust manifold for an inline 6 250? Do any of you have used parts that are in restoration condition?
I am doing a frame-off and want to keep it 100% stock, and as expected, the heat riser is mucked up pretty good.
Thanks!
Bruce
70 Chevy C10 SWB Stepside
ne72gmc is offline   Reply With Quote
Old 10-17-2018, 08:13 PM   #2
Jim Boy
Smile Re: Inline 6 Heat Riser
I went through that issue with the riser and from what I found out is that no one makes repair parts for the riser. I did however find a place that sold a complete new manifold with a new heat riser in in it. If you want I can look up my records and find the companies name. My engine was the 250. Have a good one eh!
Jim Boy is offline   Reply With Quote
Old 10-17-2018, 08:21 PM   #3
ne72gmc
ne72gmc's Avatar
That'd be great, I may go new if I can't find any good loaner units that are in decent shape.
Bruce
Old 10-17-2018, 08:36 PM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
Is it frozen and won't open all the way, or what? There are products that will loosen it up, if that is all that's wrong.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 10-17-2018, 08:49 PM   #5
Jim Boy
OK Bruce this is what I got. I ordered the manifold from a place up here called Ideal Supply. They seem to be connected with NAPA Auto Parts which I believe is USA based. A call to your nearest store might solve your problem. The part number I have is 4KB 101140 and is for the exhaust manifold and the heat riser. The cost Canadian was $225 so should be cheaper down under. You might be able to find one in the bone yard but they all have years on them and to go to all the work of putting a used one in and maybe shortly after have to take it back out I myself went for the new one It's been in for 4 1/2 years and no trouble. The choice is yours my friend. Good luck. Ron.
Old 10-18-2018, 07:33 AM   #6
bubbasimms
https://www.summitracing.com/parts/atp-101140
bubbasimms is offline   Reply With Quote
Old 10-18-2018, 12:15 PM   #7
ne72gmc
ne72gmc's Avatar
Thanks, after getting the manifold sand blasted, I confirmed it is cracked, so I need a new one anyway. Looks like the ATP 101140 is the way to go, thanks guys!
Bruce
Old 10-23-2018, 10:43 AM   #8
ne72gmc
ne72gmc's Avatar
After much research, the only OEM replacement is by ATP, but nobody has the part in stock (including ATP).
Is there any chance someone has a L6 exhaust manifold in good condition available that is within a 3 hour drive?
Bruce
Old 10-23-2018, 10:54 AM   #9
Grumpy old man
Grumpy old man's Avatar
I have a few , Let me get some pictures this morning . Shipping from Knoxville
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 10-23-2018, 11:08 AM   #10
ne72gmc
ne72gmc's Avatar
That's great, let me know what your price will be on them shipping to 68135 as well.
Bruce
Old 10-23-2018, 11:11 AM   #11
Grumpy old man
I've seen replacement heat riser springs ,I just don't remember where .
Old 10-23-2018, 11:15 AM   #12
ne72gmc
ne72gmc's Avatar
I actually need the entire exhaust manifold, after sandblasting mine, found out it was cracked.
Bruce
Old 10-23-2018, 01:19 PM   #13
Grumpy old man
I found 3 so far , I'll post some more pictures in the parts section .
