Old 10-17-2018, 09:59 PM   #1
KMAT
12 bolt rebuild
I have been searching the internet for the correct and proper way step by step how to rebuild my GM 12-bolt posi rear end.
I've got new bearings and new seals. It's going in my 67 short box Stepside C10 it is a truck posi rear end. I would like short simple answers please it would be so so much appreciated glad to be on this site I've read a lot of good information already that was has helped me with other issues again thank you.
KMAT is offline   Reply With Quote
Old 10-17-2018, 10:51 PM   #2
ZEKE68
ZEKE68's Avatar
Re: 12 bolt rebuild
Just rebuilt mine a couple of months ago. I did a lot of looking and bought a couple of books but never found a single source for information on rebuilding the 12 bolt truck. I can tell you what I found out about the required specs for setting up the rear end. But there are no short quick answers. Have you done any rear end work before? You will need a beam style inch pound torque wrench to check the pinion bearing preloading. You will need a two jaw puller to get the yoke off of the pinion. You will need some very long wrenches to set the pinion bearing nut preload. I used two 39 inch long 3/4 inch breaker bars and a 1 1/8" socket along with a plate I bought to hold the pinion while I torqued it. You will also need to remove the carrier bearings and pinion bearing and have new ones pressed on. Are there any major problems with the rear end now, or is it just a refresh?
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline   Reply With Quote
Old 10-18-2018, 09:14 AM   #3
ZEKE68
ZEKE68's Avatar
Re: 12 bolt rebuild
GM 12 BOLT TRUCK
Pinion preload torque with new bearings, 13 TO 15 inch / pounds
Pinion to ring gear back lash .006" TO .010"
Ring gear retaining bolt torque 55 ft. / lb.
Carrier bearing cap bolt torque is 60 ft. / lb.
Carrier bearing preload should be as tight as possible without hamming the side shims into place. (Tap in with brass or aluminum driver).
When checking and setting the gear mesh pattern, it is best to go back the way it came apart if you are using the old gears, and there were no issues with the rear end other than wear.
This is my 2 cents
Old 10-18-2018, 09:27 AM   #4
Mike C
Mike C's Avatar
Re: 12 bolt rebuild
Technically I guess you could find short, simple answers on rebuilding a differential, but it is a fairly technical, precise assembly so you really need a technical precise and detailed set of instructions.
Entire books are written on the how to process so don’t expect one paragraph on a message board to get you there. But the good news is there are how-to’s all over the internet. Google away.
If you don’t own a factory service manual for your truck, that is where I would start. Once you have a good, general idea of the process, then come back and ask some simple and precise questions that can answered in a short manner.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-18-2018, 10:48 AM   #5
palallin
Re: 12 bolt rebuild
Why not get a copy of the factory overhaul manual?
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 10-21-2018, 08:03 AM   #6
KMAT
Re: 12 bolt rebuild
Yes I have rebuilt one before but it was 35 years ago when I went to school for automotive. I have Googled away and all I get are guys with a half-hour story of what they did that day and very short little bits of information as for what they're doing with the rear end. Thank you very much for all of those who have gave me good information I appreciate it very much. I apologize for probably not clarifying some of the information, I'm new to this forum system I have never had a computer and I just recently have gotten this Smartphone. I have been looking all over the internet for manuals and I'm coming up empty-handed any ideas as to where I could look would be much appreciated thank you very much
Old 10-21-2018, 01:55 PM   #7
hjewell2
hjewell2's Avatar
Re: 12 bolt rebuild
the book by jeff bryant is the best hands down, how to rebuild a 7.5 8.2 8.5 8.78
hjewell2 is offline   Reply With Quote
Old 10-21-2018, 02:00 PM   #8
hjewell2
hjewell2's Avatar
Re: 12 bolt rebuild
Follow the Author
Jefferson Bryant
+ Follow
Chevy Differentials: How to Rebuild the 10- and 12-Bolt Kindle Edition
by Jefferson Bryant (Author)
3.9 out of 5 stars
43 customer reviews
See all 2 formats and editions
Kindle
$14.02
Read with Our Free App
Paperback
$24.39
21 Used from $12.75
30 New from $18.85
Old 10-21-2018, 02:03 PM   #9
hjewell2
hjewell2's Avatar
Re: 12 bolt rebuild
Follow the Author
Joseph Palazzolo
+ Follow
High-Performance Differentials, Axles, and Drivelines Kindle Edition
by Joseph Palazzolo (Author)
4.3 out of 5 stars
93 customer reviews
See all 8 formats and editions
Kindle
$16.17
Paperback
$23.63
40 Used from $14.98
47 New from $18.05
Old 10-21-2018, 09:38 PM   #10
Slowguy
Re: 12 bolt rebuild
I too would like my rearend rebuilt just because everything else on the truck will be brand new. I must have posi for the power I’m expecting. Can anyone recommend a good shop or person that does these in the Chicago/Milwaukee area?
Slowguy is offline   Reply With Quote
